Ok, so after much research I ran across a diagram for a "Diode Battery Isolator" and it seems like the solution I am looking for.
I plan on upgrading my alternator (further research is needed to determine what kind/size/etc) to handle my needs. I will upgrade my existing main battery to a Red Top Optima Deep Cell (I've read these are better for starting engines) and adding a Yellow Top Optima Deep Cell as my accessories battery (I've read that these drain slower and are not so good with starting engines). I will separate these batteries with a battery isolator (just learned they existed last night).
Now, all together I plan on having about 3500+ watt usage out of my Yellow Top to power all my accessories (3 amps, 1 inverter, & my Lilliput), which is why I decided to go with such a heavy duty battery.
Here is a link to the diagram I've found:
http://www.custombatterycables.com/i...20isolator.GIF
Now, my question to you is: Is this a good idea or is there something better that I haven't come across yet?
Thanks!
