The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Newbie
Thread Tools Display Modes
Old 05-02-2008, 12:46 PM   #1
haribo862003's CarPC Specs
haribo862003's Avatar
Vehicle: ford fiesta mk5 2000
My Photos: (0)
hi, i'm new to this in car pc stuff
Hi guy/girls.
I've just start buying all the bit for making my carpc. I would like to no if i should of bought sumthing different.
Here what i got planned for buying and bought:
1. First off not bought this yet but a via epia mii 12000 mini-itx motherboard, but finding it hard to find, so think the 10000.
2. Got, 512mb ddr ram
3. Got, Seagate barracuda 160gb 7200rpm hdd
4. Got, bu303 gps mouse reciever
5. Got, bluetooth usb dongle
6. Got, LINKSYS WUSB54G WIRELESS-G USB NETWORK WIFI LAN ADAPTER
7. Got opus 150w psu.
got the list from a website called stevieg.org
haribo862003 is offline   Reply With Quote
Sponsored Links
Old 05-03-2008, 07:13 AM   #2
HiJackZX1's CarPC Specs
HiJackZX1's Avatar
Vehicle: 03 Dodge Durango SLT
My Photos: (162)
You have to give us more information. What do you want the PC to do.... will it play video? Will it connect to the internet? Is there a budget? In the past I had a M10000 which i think is the model before the m2 models, and it was cr@ppy with video. Maybe the m2s' are better?
Anyways, give us more details on what you expect the PC to do.
PLANNING [IIIIIIIIIIIII] DONE
ITEMS [IIIIIIIIIIIII] DONE
INSTALL [IIIIIIII---]
BUDGET [IIIIIIIIIIIIIIII]IIIIIIIIIIIIII
HiJackZX1 is offline   Reply With Quote
Old 05-05-2008, 11:27 AM   #3
My Photos: (0)
cont
The main thing i want the pc to do is hold my music, navigation, handsfree. not bothered about video's. Internet would be good not to bothered at mow. The 1st three thing are the main ones. Budget not very big but am good at saving if i really need sumthin.
whats a good, not to expensive motherboard i could use with the stuff i got.
Old 05-05-2008, 11:36 AM   #4
-zip-'s CarPC Specs
-zip-'s Avatar
Vehicle: 2000 Protege
My Photos: (1)
check out the Intel Little Valley boards, D...GLY
Carputer
Installed Since April 2, 2005
Intel D201GLY|Fusion Brain|Audigy2 NX||ODBPros ODBII|Engenius362ext |Motorized lilli|GPS Rikaline 6010|Opus 150|Powermate|Ergonomic Touchpad|
Sound Stage
Eclipse CD8455|MTX TA3404+421D|Infinity Comps|ID 12" Sub
-zip- is offline   Reply With Quote
Old 05-05-2008, 06:29 PM   #5
DodgeCummins's CarPC Specs
DodgeCummins's Avatar
Vehicle: 96 Dodge Ram 2500 Cummins Diesel (turned up)
My Photos: (20)
Sounds about like the one I had.
I ran a laptop size drive for the power/heat/room to put it. I also added a PCI video card to get a better output.
current projects
DodgeCummins is offline   Reply With Quote
Old 05-08-2008, 07:11 AM   #6
My Photos: (0)
so which is the best:
Intel D201GLY Little Valley with 1.33 GHz Celeron Processor
or
VIA EPIA MII 12000
or
Also been told these are good
Jetway J7F2 1.5GHz C7D CN700 Mainboard and Commell LV-677D Intel Core Duo Mainboard.
Also what other items do i need to get my carpc up and running
Old 05-08-2008, 07:16 AM   #7
Super Moderator
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
From the boards you listed, the little Valley board is superior in terms of computing ability and minimal power draw.
As far as what else you need, I suggest thoroughly reading the FAQs.
Here are some resources to helpkick-start your research:
http://www.mp3car.com/vbulletin/advfaq.php
http://www.mp3car.com/vbulletin/forumdisplay.php?f=106
http://www.mp3car.com/wiki/
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 05-08-2008, 07:58 AM   #8
My Photos: (0)
do you no where i can get a cheap Intel D201GLY2 little valley from, found one on internet for $67.24 in P+P
Old 05-08-2008, 08:50 AM   #9
labenedict's CarPC Specs
Vehicle: 2003 Hyundai Sonata
My Photos: (0)
I got my D201GLY2 at pcsuperstore.com and was satisfied.
labenedict is offline   Reply With Quote
Old 05-15-2008, 07:52 AM   #10
My Photos: (0)
arrived
My D201gly2 arrived today. Think i've got most things to get it up and running. So i now need to put it to gether. I also need to buy some power cables, shielded signal cables for installing into my car and a screen. But will get tht sorted out in a bit, will get it up a running in my house and get things installed.
Sponsored Links
Old 05-15-2008, 08:58 AM   #11
Kimota's CarPC Specs
Kimota's Avatar
Vehicle: POS 05/Mazda/RX8
My Photos: (0)
Hello,
You mentioned handsfree I believe your referring to using your cell phone via bluetooth with CarPC? I've been able to get handsfree to function with two different front-ends Road Runner and StreetDeck but found the audio quality (how my voice sounds to caller) to be okay at best.
For handsfree you may want to consider an after market unit like the ones made by Parrot, I've found the sound quality with them to be FAR superior to what you can achieve with a CarPC.
pssstt
Kimota is offline   Reply With Quote
Old 05-15-2008, 12:44 PM   #12
My Photos: (0)
was wondering how i connected the seagate barracude to my d201gly2?
Old 05-15-2008, 01:55 PM   #13
FusionFanatic's CarPC Specs
FusionFanatic's Avatar
Vehicle: '07 Ford Fusion
My Photos: (50)
I have the D201GLY2A (same board as your's, but with different heatsinks and a CPU fan). next to the RAM stick there should be 2 SATA port and 1 PATA (IDE) port. your HDD plugs in the one of those ports.
then connect power from the opus. (you may need a PATA>SATA molex adapter if your HDD is SATA).
FusionFanatic is offline   Reply With Quote
Old 05-15-2008, 02:46 PM   #14
My Photos: (0)
hi is this what i need? Probably guess by now that i don't no much about computers but i learn as i go along
Sponsored Links
vB code is On
Trackbacks are Off
FS: Car PC and monitor TM-701L.........other PC stuff.... slizm Classified Archive 12 06-15-2006 10:22 PM
Installing car PC in 1996 Honda Civic PredatorCoder Newbie 8 08-18-2005 07:58 AM
For Sale for all you aussies. Complete mp3 car pc Holden__V8 Classified Archive 20 04-09-2005 05:30 AM
Car PC EZ 2.4 SDC/Inverter Controller - NOW Avail! hd54321 Power Supplies 1 02-24-2005 12:42 PM
Car power supply (battery charger) from old pc supply stimps Power Supplies 8 08-24-2004 07:59 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
