The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Newbie
Thread Tools Display Modes
Old 05-02-2008, 04:28 PM   #1
My Photos: (0)
Power Xenarc Brand Monitor
I just purchased a Xenarc Monitor and was doing some searching around the fourms, and couldn't find a direct answer to a question i had.
How do you do the following suggestion?
2) Use a Xenarc brand monitor wired directly to the car's electrical system (ACC line). The Xenarc has a built-in regulator.
By wiring it to the ACC line, the monitor will turn on/off with the car's ignition.
My orignal question was how am i going to power the monitor, and now that I have figured that out, how do I do this. Any feedback would be helpful.
rizzo0917 is offline   Reply With Quote
Sponsored Links
Old 05-03-2008, 06:31 AM   #2
HiJackZX1's CarPC Specs
HiJackZX1's Avatar
Vehicle: 03 Dodge Durango SLT
My Photos: (231)
Never power anything off the ACC line. It is only made to send signals to turn a device on. Here is how you do. Go to your local autoparts store and buy a relay. Then follow these:
Using a Relay to Turn On you screen:
Step1. Connect the ACC lead pole 85.
Step2. Apply ground to pole 86 (ground from radio wiring ground).
Step3. Put positive voltage from the battery (positive from radio wiring positive) to pole 87.
Step4. Attach screen positive to pole 30 .
Step5. Attach ground of screen to ground (ground from radio wiring ground).
PLANNING [50%]
CAR PC ITEMS [75%]
INSTALL OF PC [80%]
INTERIOR MODS [35%]
BUDGET [380%]
HiJackZX1 Work Log
HiJackZX1 is online now   Reply With Quote
Old 05-03-2008, 07:17 AM   #3
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
You find a power line that only receives power when the key is in the ON position. There are some devices that are only on when you turn on the vehicle like cigarette lighters, power seats, power mirrors, and the like.
The only way to make 100% certain is us a digital multimeter and measure the voltage of a power line with the key off (should read 0v) and witht he key on (should read ~12v).
The power draw of an LCD is not very heavy.
As such, there should be no issue tapping into an existing circuit for the purpose of powering an LCD. Lots of members power their LCDs this way.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 05-03-2008, 09:12 PM   #4
rgarjr's CarPC Specs
rgarjr's Avatar
Vehicle: 98 Lexus GS300
My Photos: (37)
another way to power it is if your Psu has a 12v rail.
My carpc worklog
rgarjr is offline   Reply With Quote
Old 05-03-2008, 09:33 PM   #5
Fusion Brain Creator
2k1Toaster's CarPC Specs
2k1Toaster's Avatar
Vehicle: 2001 Honda Civic EX Coupe
My Photos: (1)
True it should not be a problem but it is sort of an electrical no-no to cascade things off of what is supposed to be a trigger line only. It leads to bad habits and people thinking they can power anything off of it, and it is better to power it off of an IGN tripped relay.
But again, powering it directly from the ign line should be ok.
Old 05-04-2008, 03:00 AM   #6
lucegunz's CarPC Specs
My Photos: (0)
see im a total newb when it comes to electrical work is it ok to power this thing off my existing radio power cable which will not be used anyway since this monitor is basically going where my radio is... the thing im talking about powering right out of the readio is the xenarc MDT-X7000 i was planning on doing this on monday and it seems logical since that power wire which has been conveniently run there by the manufactuerer is going to go to waste if i dont use it
lucegunz is offline   Reply With Quote
Old 05-04-2008, 03:30 AM   #7
audi's CarPC Specs
audi's Avatar
My Photos: (1)
another way
i use remote out for power amp from psu out 2years now
i have M2-ATX with small rele 12vdc connectto j6 common to +bat
and normaly open to car amp + xenarc
audi is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Xenarc 700IDT (700-IDT) Power Pinouts cMags LCD/Display 1 01-21-2008 06:22 PM
WTB: Xenarc TSV power supply scotty562 Classified Archive 4 09-10-2006 07:26 AM
FS: ITPS shutdown controller and PW-70a MINI-ITX power supply hanzacra Classified Archive 4 08-07-2005 10:32 PM
Xenarc 700TS / hardwire power dnorrell LCD/Display 18 11-29-2004 10:04 AM
Power Source for Xenarc legend5761 LCD/Display 7 11-19-2004 02:39 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
