The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Newbie
Thread Tools Display Modes
Old 05-08-2008, 07:27 PM   #1
My Photos: (0)
240-12v psu modification, help!!!
hi im in the process of installing my xbox into the car, which at the same time is being converted into a carputer, however rather than running an inverter and wasting huge amounts of power, and buying a new psu, can i tap into or modify the current psu to run straight off 12 volt?? i managed to wire it up at the end of the board and get power, yet it seems a bit low and the on/off power button and eject no longer work so im thinking they must affect the power further up the board...
if any one has pics of an xbox or owns one you should be able to look at it and know what im on about
im a newbie here so not reall tech language compatible, but jsut looking for someone to tell me what im looking for? what would be the first point that the psu would be using 12 volt power from the 240?????
cheers.
haven666 is offline   Reply With Quote
Sponsored Links
Old 05-09-2008, 12:51 AM   #2
Raw Wave
Rob Withey's CarPC Specs
Rob Withey's Avatar
Vehicle: '97 Vauxhall Corsa 1.5 TD
My Photos: (0)
Search for Presslabs forward converter.
Most switchers don't work the way you think - they don't convert to 12v and then regulate to the different outputs. Generally they rectify the 240 and then switch that through a transformer using PWM to regulate. You'll probably be replacing the transformer with a custom piece.
6yr old first install died 20/8/2005 as result of bad bios flash.
New system : 6x5x2" contains 1GHz C3 PCM9373, ISR based PSU, 512Mb flash DOM, 8Gb CF HDD, 98Lite, DirectShow based frontend.
GPS : Rikaline 6010.
Display : LTM08C351 + LVDS receiver.
Rob Withey is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
12v PSU output daveg360 Hardware Development 6 08-15-2005 02:38 AM
12V PSU for Pundit? Which one? Alex_gregory_uk Power Supplies 0 06-01-2005 02:28 AM
Frequently Asked Questions bgoodman The FAQ Emporium 33 05-03-2005 06:25 PM
Lilliput +12v PSU...how can it work? MikeH Power Supplies 2 01-09-2004 09:31 AM
usb hub with 12v psu etrik General Hardware Discussion 4 06-30-2001 01:06 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
