The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Newbie
Thread Tools Display Modes
Old 05-08-2008, 09:40 PM   #1
My Photos: (0)
Questions about powersupplies and SDC
Hey guys!
New to the whole carPC thing, but have been lurking on and off for a year or so. Finally made the plunge and bought a 7" touch screen off of another forum. Not here yet, but the power supply issue has been bothering me!
Basically, what I want to do, is have the power supply (either inverter, or DSATX)turn on and turn on the computer whenever I have the key in the ON position (meaning no acc such as a/c and.or radiator fan). I want this because I go to the drive-in everynow and then, and don't want to bring a portable boom-box for the audio.
I am in a toss up of what powersupply to use. I am either between an inverter and a DSATX 220w.
System as follows:
Celeron 2.4
1gb ram
40gb HDD
ASRock atx mobo
slot load dvd.
I have found this diagram which uses an inverter:
courtesy of: http://www.mp3car.com/vbulletin/383433-post21.html
That is what I would like to do. With the DSATX, is that one of the selectable SDC modes? Obviously the key will be in the ON as opposed to just in the keyslot.
**Also, will be running 2 amps (fronts&subs)
I am totally confused, I have read and read and read, but nothing has really confirmed anything for me. Inverter, or DSATX?
vip3r87 is offline   Reply With Quote
Sponsored Links
Old 05-09-2008, 06:31 AM   #2
My Photos: (0)
I might just run a momentary switch to my dash, so whenever i want it on, I can turn it on, and whenever I want it off....I can turn it off
this way no worries about if it powered down properly....hmmmm
Old 05-09-2008, 08:12 AM   #3
Admin. Don't bug or I'll byte.
Bugbyte's CarPC Specs
Bugbyte's Avatar
Vehicle: 2001 VW Beetle
My Photos: (19)
You need something called a valet switch. Rather than a momentary switch, use either an SPST switch or an SPDT one, wired like this.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 05-09-2008, 02:39 PM   #4
My Photos: (0)
okay, so what i am going to be doing now is this:
run an inverter(or dsatx 220w) power supply, and mount a momentary switch to my dash, connected to the motherboard power/restard pins (stealing from old computer case). what would be the best way to do this? I assume relays will still be involved? Basically, what i want, is even if the car is parked, ie. not on, is to be able to push the momentary switch to turn on the system.
Also, if possible, I want the system to be powered (not shut-down) when the switch is pressed (car off), and when i crank the engine for the power to stay on, and not reboot the PC.
I will be using either of the 2 mentioned powersupplies. What would be the best way to do this? All the while being able to turn off the dsatx or inverter when I leave the car so no power is going to it at all
I am sorry for the confusing wordings...I am having trouble saying what I really want to be able to do.
Old 05-09-2008, 10:03 PM   #5
Bugbyte's Avatar
My Photos: (19)
I don't think you are thinking this through fully. If you wire either the inverter or the DSATX to your battery, the only function of the ignition key is to signal a start or a stop to your PSU.
That means you can start the computer anytime you want without the key in the ignition as long as you put some power on either the switched input on the DSATX or the com port for your inverter solution. Basically, just run power from your battery, through a switch to your switched input.
However, if you ALSO use the ignition key accessory line to signal the computer to turn on and off, you will get your power supply out of synch with whether the car is on or not. Basically, you will push the momentary switch to turn it off, it will shut down, and then when you turn the car off the computer will start up again even though the car is off.
Hook it up the way 2k1Toaster says in the post I linked you to. That will do what you want.
Old 05-10-2008, 07:08 AM   #6
My Photos: (0)
yea I decided too, I noticed that the way i was trying to describe what I want isnt even correctly what I want
Thanks alot guys!
Cant wait to start my build
Sooo excited!
Old 05-11-2008, 09:51 AM   #7
Bugbyte's Avatar
My Photos: (19)
There's a clearer diagram here on post #29.
Old 05-11-2008, 05:48 PM   #8
brucedog's CarPC Specs
brucedog's Avatar
Vehicle: 2000 Saturn LW Wagon
My Photos: (22)
FYI
The Vector brand of inverter that I bought from
www.invertersrus.com
can be ordered with a remote turn-on switch. It plugs into the inverter control panel using a telephone-type connector, has an about 16 foot cable attached, and a neat little contol panel. Looks like it's designed to be used for a motor home or something. I mounted mine in a neat cutout in my glove box - works like a charm.
Happy CarPC'ing!
brucedog is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
