The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Newbie
Thread Tools Display Modes
Old 05-11-2008, 05:20 PM   #1
pabla007's CarPC Specs
My Photos: (0)
Cool Can i hook up a dell laptop screen to a compaq laptop?
i have a spare dell laptop screens and trying to hook it up to a Compaq laptop. is it possible? and if possible how?
* 6 days ago
* (Tiebreaker)
Additional Details
3 days ago
I have three different type of laptop. Main Laptop is Compaq Presario 2100. Compaq Presario 2100 with a 30Gb hard drive, 512MB of memory, and a 1.8Ghz AMD XP 2400 processor.
I would like to use screen from Compaq Presario 1247. Display 12.1 inch HPA display.
Video Graphics Trident Cyberblade 3D graphics
* High-performance 3D graphics
* Maximum internal resolution of up to 800 x 600 x 16 M; with external monitor – 1280 x 1024 non-interlaced
* 24-bit color provides up to 16 M brilliant colors
* MPEG full-motion video playback
* Audio CD player
* Video player (AVI, MPEG and others)
Video Memory 4 MB video memory
Lastlaptop tOSHIBA tECRA 8100:Processor 500MHz Mobile Pentium III
RAM/Memory 192mb
Hard Drive 10GB
Optical Drive CD-ROM
LCD Screen 14.1"
I would like to know if i could connect Compaq Presario 1247 and Toshiba Teca 8100 to Compaq Presario 2100. I want to remove screen from following laptop and connect to main laptop.
help me
pabla007 is offline   Reply With Quote
Sponsored Links
Old 05-11-2008, 05:28 PM   #2
muldrick's CarPC Specs
muldrick's Avatar
Vehicle: 2004 Hyundai Accent
My Photos: (2)
I don't know, but did you see THIS?
Now faith is being sure of what we hope for and certain of what we do not see.
muldrick is offline   Reply With Quote
Old 05-12-2008, 02:21 PM   #3
Grrrmachine's CarPC Specs
Grrrmachine's Avatar
Vehicle: Audi 80 Coupe 1.8 1982
My Photos: (8)
Simplest answer is no. Every laptop LCD uses its own proprietory controller board for graphics, and on most laptops thats hardwired to the motherboard as a soldered component or an unremovable element of the motherboard layout itself. Your best hope is to try, but dont be surprised if 10 hours later you haven't got any image AND you've burned out a screen or two from incompatible voltages.
Grrrmachine is offline   Reply With Quote
Old 05-12-2008, 02:27 PM   #4
Fusion Brain Creator
2k1Toaster's CarPC Specs
2k1Toaster's Avatar
Vehicle: 2001 Honda Civic EX Coupe
My Photos: (1)
Probability of Dell to Compaq transpant working is very low.
Compaq to HP or visa versa has a higher success rate.
Dell to Alienware is a higher success rate.
Basically if it is made by the same company, they usually cut corners and use the same parts in different flashy cases.
But the best way to know is to take apart the screen and read the serial/model number off the TFT screen itself. The video card is irrelevant. The actual screen model is needed. Probably Hitachi...
Then google the numbers and find pinouts for the screen. If they match it will work. I doubt they will. If the signals match but not in the same area, then you will need a custom cable made which will be a PITA because they are very small.
good luck.
Old 05-21-2008, 10:50 PM   #5
wired48's CarPC Specs
My Photos: (0)
It can be done but it is not quick and its not easy. A straightfoward swap is highly unlikely, but if you want to run the screen externally get hold of a LVDS or TTL controller and get to work. Check the following link
http://www.mp3car.com/vbulletin/lcd-...-lp150x04.html
wired48 is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Powerbook g4 12" + other laptop parts (mainly from a D800) sabre Classified Archive 12 07-24-2006 10:12 AM
FS/FT: Dell Inspiron 8100 Laptop...CarPc emailthis1 Classified Archive 5 09-20-2005 08:59 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
