The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Newbie
Thread Tools Display Modes
Old 05-12-2008, 10:27 AM   #1
My Photos: (0)
Pleas some help me on how to power my lcd of the m2-atx
Hi there mate i have been trying to power my 8"LCD of the P4 power cable of my m2-atx but i have had a very strange issue.
My car PC st up is
Jetway Via C7 2Ghz processor with a sata laptop hard drive n a pci usb card so i think i sould have more than enought power left to power the LCD.
I connected everthing up it seem to work fine i can enter the bios but as soon as it gose past saying windows XP is loading i get no display it keeps saying no VGA display. So i hooked up the LCD using an extention from a home power socket and used the LCD,s standard home plug power cable and run the lcd just to see if it worked an it works fine but as soon as i connect it to any of the molex power sourcers of the M2-ATX i get the issue where it says no VGA signle after it gose past the windows XP loading screen. Could it be that my inline fuse rating is too low as i used a 15amp blade fuse between the + 12v power line from the car to the M2-ATX, please i need some help would be very much appreciated as i am totally confused
jarule9uk is offline   Reply With Quote
Sponsored Links
Old 05-12-2008, 11:07 AM   #2
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
Use the yellow & black wires from a HDD power connector.
Yellow = 12v
Black = Ground
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 05-12-2008, 12:27 PM   #3
My Photos: (0)
ok thanks will try
Old 05-12-2008, 04:26 PM   #4
My Photos: (0)
tried that same problem, i also tried connecting everthing up to an desktop atx power supply and tried running the LCD of the hdd and p4 power cables of the desktop atx power supply and still get the same issue. So the LCD will not work unless it is plugged on its own for some reason
Sponsored Links
vB code is On
Trackbacks are Off
M2-ATX Problem - Fan runs but does not boot ! Autonator Power Supplies 62 11-14-2006 05:22 AM
M2 ATX Power on problem JWise1203 Power Supplies 5 07-26-2006 11:24 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
