The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Newbie
Thread Tools Display Modes
Old 05-16-2008, 06:06 PM   #1
My Photos: (0)
Line-level sound card output to amplifier
Hey everyone
I read the thread on how to connect your computer's audio to your exisitng HU/amp, but I didn't see this issue addressed:
Is the output from the sound card "line-level/pre-amp"? I.e. do I need to use a speaker-level -> line-level converter before running the sound card output to my amp's input? I have a feeling that it is not a low-line level output, but I didn't see that issue addressed in that thread.
Thanks for the info!
Rocket3004 is offline   Reply With Quote
Sponsored Links
Old 05-16-2008, 11:26 PM   #2
rgarjr's CarPC Specs
rgarjr's Avatar
Vehicle: 98 Lexus GS300
My Photos: (40)
the audio off a pc's sound card is low level. So you simply just run a 3.5mm to dual RCA type adapter, then run regular RCA type patch cables to your audio amp.
My carpc worklog
rgarjr is offline   Reply With Quote
Old 05-17-2008, 02:59 AM   #3
My Photos: (0)
Perfect, thank you. for some reason, I was thinking that it wasn't a low level output, but then again, computer speakers generally have a separate amp.
Any idea what the voltage is coming out of the sound card? I don't know if the even spec that kind of thing... I guess I'll have to check w/ the mobo documentation...
Old 05-17-2008, 11:47 AM   #4
FusionFanatic's CarPC Specs
FusionFanatic's Avatar
Vehicle: '07 Ford Fusion
My Photos: (56)
the output voltage is probably different for each mobo/soundcard. you can measure it with a multimeter set to AC volts.
the output will vary depending on volume and tone level. you'll need to use a test-tone to give a constant output, then with volume up all the way; measure either channel's positive to ground (audio ground, not chassis ground).
NOTE: this will be much easier to do from the RCA adapter outputs.
FusionFanatic is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
USB sound card output level amemo06 Car Audio 4 01-03-2008 03:07 PM
bluetooth woes gentoocar Linux 120 12-23-2007 12:04 AM
Headphone vs line level outputs from computer, etc. timeshifter Car Audio 3 12-31-2006 12:21 PM
Sound Card discussion, 4.1, sound quality, need help jedi7001 General Hardware Discussion 1 05-19-2005 09:47 AM
Sound card reccomendation for **music** TWBarrett Car Audio 12 09-09-2004 09:40 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
