Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 05-22-2008, 10:43 PM   #1
D3LTR33 is an unknown quantity at this point
What Power Supply for Laptop Install?
Hey guys. I was ******* around with a dead laptop today and managed to fix it so now i'm gonna turn it into a carpc.
How does a laptop install differ from a pc install? I've read the laptop faq and it was all pretty much common sense stuff.
I realise that i will need one of webmaster's auto power on modules to turn it on and off. But what about power supply? Do i just use the same power supply as i would for a carpc? I assume i would have to hack up the laptop power cord to wire it to the PS yes? And don't most power supplies have startup sequences or something built in? Would it conflict? How would the power supply know when to supply power if the auto startup module is handling that?
So basically;
Auto startup module connected to laptop
laptop cord hacked into regular power supply
xenarc connected to regular power supply
power supply connected to battery
What is missing?
Just trying to get everything clear as possible in my mind before i take the first steps.
Cheers
edit: my power cord has INPUT: 100-240V 1.5A OUTPUT: DC 19.5V 3.34A
edit: Would the startup module built into the carnetix do exactly the same thing as the webmaster module? It appears that the carnetix one needs to be soldered in, the same way the webmaster module needs to. So it would be easy to pick one or the other and i see how they couldn't conflict.
D3LTR33 is offline   Reply With Quote
Old 05-22-2008, 11:58 PM   #2
xelz's Avatar
xelz is on a distinguished road
there are 2 ways of doing this. The better more expensive way is:
power supply (like carnetix) w/ builtin startup mod, so you wouldn't need webmaster's auto power on mod.
the cheaper way (the way i do it) is:
get a cheap laptop car adapter on ebay, hack it up and connect that to the battery along with the xenarc, and get the auto startup mod. (of course connect the screen and adapter to a relay to turn them on when the car turns on).
Another way is use an inverter to power the laptop.
James
xelz is offline   Reply With Quote
Old 05-23-2008, 12:13 AM   #3
Thanks xelz.
I been doing more reading and i think i'm getting the gist of it. It appears that by using the carnetix, my laptop battery won't charge? I've only seen this mentioned in older threads, is this still an issue? Something to do with the "Charger ID" wire in the power cord.
Also, the carnetix supports 18V, 19V, or 20V. My power brick says 19.5V. Is this a big enough difference to be a problem?
Old 05-23-2008, 12:26 AM   #4
xelz's Avatar
i'm pretty sure .5v won't really make that much of a difference. i'm powering a 12v router right now with a 19.5v input power, but i tried the same thing w/ a 12v tv antenna and i saw sparks fly.
another option is get the ebay car adaptor and connect that to the 12v of the carnetix.
James
Old 05-23-2008, 12:50 AM   #5
FusionFanatic's Avatar
FusionFanatic is an unknown quantity at this point
I think I remember reading that the "no battery charging" issue was only on certain model Dell laptops.
I used an old Dell Inspiron 8000 in my previous carPC setup. I used a cheap eBay auto adapter to power it. the OEM power cord has 3 wires, the eBay adapter cord had only 2 wires but the battery still charged up fine.
FusionFanatic is offline   Reply With Quote
Old 08-04-2008, 12:42 AM   #6
Going back to this, i've bought all the components for my install and i'm gonna wire it all in as soon as i get an answer to this question:
How exactly do i wire the laptop to the Carnetix? My power cord has the barrel connector on the laptop end, a brick in the middle, and the ac mains plug.
Do i chop off the brick and ac mains plug so that i'm basically just attaching the barrel connector to the Carnetix?
Old 08-04-2008, 07:41 AM   #7
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Yup.
That or purchase another barrel connector from an electronics shop.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
USB Syncroized 5V@8A power supply POL. Now Taking Orders!!! Beehphy User Innovations 110 06-23-2009 04:22 PM
power supply confusion CapnBoost Power Supplies 3 04-26-2007 08:59 AM
My low cost, easy to build power supply... SkinnyBoy Power Supplies 52 09-27-2006 07:10 PM
Power Supply MrGee Newbie 9 06-21-2006 05:44 PM
power inverter power supply shutdown problem launter Power Supplies 10 09-21-2005 12:12 PM
