Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 06-12-2008, 07:59 PM   #1
BLACKonBLACK98 is an unknown quantity at this point
HELP! starting up for the first time. nothing happening.
so i got most of my stuff... hooked everything up according to manuals and powered up. the cpu fan is spinning. monitor is no input. this is my first computer build so i'm not sure what i'm supposed to do now. according to the manual it should be showing post (whatever that looks like).
msi fuzzy gm965
intell t8100
let me know if theres something else youd like to know to help me. thanks guys.
BLACKonBLACK98 is offline   Reply With Quote
Old 06-12-2008, 08:01 PM   #2
Raw Wave
lostreception's Avatar
lostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud of
any beeps from the board
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
[(o)______(o)]b VanPimpin'
LostReceptions Apps D/L Here
GPSGasoline- Rewriting
CarPCNetwork
lostreception is offline   Reply With Quote
Old 06-12-2008, 08:02 PM   #3
no sir.
i should also add that the power led is not coming on, but i'm not 100% on that since i had to switch it up to match the connections on the board. the power button does work and the cpu fan spins but thats it.
do i need to install bios or drivers first? i did not get the cd since i bought an open box but i can dl from msi.
Old 06-12-2008, 08:13 PM   #4
Raw Wave
try removing the cmos battery (little watch battery for a minute or two) then replacing if that doesnt work try running only the PSU, mobo, CPU+heatsink+fan, internal speaker and see if you get a beep
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
Old 06-12-2008, 08:20 PM   #5
i removed the battery and it didnt make a difference. there is also a jumper setting to clear cmos. do you think i should do that until i get it figured out?
couple other things: p32 keyboard is flashing when i turn it on... usb optical drive mmakes a little noise.
i will try taking off everything but the motherboard/cpu, ps, moitor, and keyboard. i have read something about ram compatability causing issues as well. do you think i should remove it?
Old 06-12-2008, 08:29 PM   #6
TheSovereign's Avatar
TheSovereign is an unknown quantity at this point
If you remove the ram, you should get some beeping...
TheSovereign is offline   Reply With Quote
Old 06-12-2008, 08:33 PM   #7
well i stripped it all the way down to motherboard/cpu/psu and still no beeps.
Old 06-12-2008, 08:43 PM   #8
tigergibb's Avatar
tigergibb is an unknown quantity at this point
possibly a doa(dead on arrival) motherboard. ask for a replacement?
post(power on self test) should at least come on to tell you what's wrong.
2003 Nissan Xterra Worklog
Total amount spent so far: $1196.64
You will probably spend AT LEAST 2x what you initially budget for your CarPC Project!
2003 Nissan Xterra - Modifications
tigergibb is offline   Reply With Quote
Old 06-12-2008, 08:52 PM   #9
ugggh. i really hope not becaue it was a final sale item. i'm assuming that means i'm screwed if it doesn't work.
Old 06-12-2008, 09:04 PM   #10
anybody else?
Old 06-12-2008, 09:21 PM   #11
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
Something like that happened to me; fan spinning but no startup - i had the P4 connector unpluged.
treetop777 is offline   Reply With Quote
Old 06-12-2008, 09:23 PM   #12
colin's Avatar
colin will become famous soon enoughcolin will become famous soon enough
A friend of mine had the same thing on his test bench a few days ago, he wasn't giving it enough power. Make sure it's not being under-powered.
colin is offline   Reply With Quote
Old 06-12-2008, 09:57 PM   #13
i do not see a p4 connection on my board.
i am using the 120w psu that came in my case untile i move it into the car and switch over to my opus 320w. with nothing plugged in but the cpu (35w) and 1gb of ram it still didn't work right.
Old 06-12-2008, 10:30 PM   #14
power led is coming on now (was a connector issue), cpu fan turns on, harddrive spins up, usb optical drive works, ps2 key board blinks.
just no beeps or video out.
Old 06-12-2008, 11:16 PM   #15
colin's Avatar
Is there an onboard speaker or do you need to attach the case speaker? Make sure there's something for it to play sound out of to alert you. Remove the RAM alltogether and try to force the system to beep to be sure that you're at least capable of getting them.
Does the screen turn blank or does it just stay in a low-power state?
Time of Arrival is relative to Midnight instead of current time - 1.1.0.8 - 1.1.0.0 froalskiner StreetDeck Bug Reports 27 03-04-2008 03:46 PM
Indexing music in 1.0.9.8 Failed hovalistic StreetDeck 0 07-07-2007 12:19 PM
Longest time between joining mp3car and actually starting project? dodgetimes2 General MP3Car Discussion 38 06-14-2005 08:18 PM
ME 2.0 Official Bug Reports phat_bastard ME Archive 67 01-31-2004 07:27 PM
