Unless your display accepts DVI-D inputs, no.
Most motherboards have SPDIF outputs on them, even if your case does not have port for it. You can hook a connector up to these pins to get an COAX output. An optical digital audio port uses the SPDIF signal and a +5v to run the LED, but the signal is the same.
Progress - VIA EPIA SP8000 | 120 Opus Power Supply & Case | 1GB Ram | 120GB 2.5" Hard Drive | Bluetooth 2.0 | GPRS/3G | Wifi | Road Runner/LSX 2.0 (waiting for a day skin for 3.0) | iGuidance 4.0 | Lilliput 7"
Reason: spelling
