Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 07-22-2008, 10:22 AM   #1
CarPC with factory amp?
Alright, I have been searching around but I can't seem to find out how to hook the PC up to my factory amp when I take out the head unit. It is a new Civic Si with a factory sub. I am trying to get away without buying a new amp since there is only 1k miles on it.
its4show is offline   Reply With Quote
Old 07-22-2008, 01:04 PM   #2
HiJackZX1's Avatar
It should be similar to a normal amp and have a remote lead from the head unit to the factory amp. Once you find that lead you use a software called AMP_CTRL or VOLUME_AMP_CTRL. I then bought a device called a PAC TR-4. Its a small device that sends a amplified signal to the remote lead to ensure it turns on.... You then connect the other end of this device to pin #4 on your serial port. 2 other wires also come out of the TR-4, one goes to Ground and the other to a 12V source. Everytime you turn on the car, the TR-4 will wait for a signal from the serial port then turn on once the Amp_CTRL turns on pin #4 on the serial port.
Have you tried locating the AMP and looking at it? It should say what is what. The connections should be 12V+, Ground, RMT (Remote wire), and audio ports. Once you locate the lead wire (RMT) just find that same wire were the head unit is.
PLANNING [100%]
CAR PC ITEMS [100%]
INSTALL OF PC [100%]
BUG WORKOUT [75%]
INTERIOR MODS [50%]
BUDGET [380%]
HiJackZX1 Work Log
HiJackZX1 is online now   Reply With Quote
Old 07-22-2008, 01:08 PM   #3
dhantiflag's Avatar
i have a 2008 civic SI and i used the factory amp... give me a bit and ill get some information for you (im at work currently)
dhantiflag is offline   Reply With Quote
Old 07-22-2008, 01:22 PM   #4
dhantiflag's Avatar
Ok First thing... buy yourself a wireharness... trust me.. its better to spend 10 dollars then to have to cut your stock wiring...
with that said. i purchased my harness at local audio store so im sure you might be able to do the same.
if not look online
after that there is 1 wire you will have to cut, because on the back of our radio we have two harness's
we have 1 small plug and 1 large plug. you need the harness for the large plug because that is where all your audio wires are..
however, the small plug has your AMP_REMOTE (light blue) wire on it.
i connected this to the ignition wire off the large plug, so now whenever my car turns on AMP turns on...
i also have my PC connected to this with a switch in the middle.
but once you get the harness, it should tell you what wires are what speaker, hook up to RCA then get a Y adaptor to 1/8 plugs and plug into PC.
if you need more help from there PM me ill gladly help with what i can!
thanks!
also check out www.8thcivic.com my name is ohiocivicracer on there they have a lot of great information!
edit:
pulled from 8thcivic.com
:Radio Harness
+12V DC Constant White
Switchedd Accessory Violet
Ground Black
Power Antenna Gray
Remote Turn On Light Blue
Illumintation Red/Black or Gray
Left Front + Light Green
Left Front - Pink
Right Front + Gray
Right Front - Brown
Left Rear + Yellow
Left Rear - Brown
Right Rear + Blue
Right Rear - Orange
:Amplifier Outputs
Left Front Mid + Light Green
Left Front Mid - Pink
Right Front Mid + Gray
Right Front Mid - Brown
Left Rear Mid + Yellow
Left Rear Mid - Brown
Right Rear Mid + Blue
Right Rear Mid - Orange
Subwoofer 1 + Green
Subwoofer 1 - Red
:At Speakers
Left Front Tweeter + Red
Left Front Tweeter - Green
Right Front Tweeter + Pink
Right Front Tweeter - Blue
What do I need for factory head unit controls with carpc in oem integration cletusb Newbie 1 07-29-2008 07:21 PM
Unusual amp shut off problem....please help! mike40370 Car Audio 12 12-05-2007 04:13 PM
Help needed not another amp to carpc question AstraBoyRacer Car Audio 2 09-01-2007 07:03 PM
Wiring CarPC from Amp wiring? Calipso Newbie 6 02-03-2007 05:32 PM
Those with a hu, amp, and carpc falconey Car Audio 1 09-14-2004 07:27 AM
