Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 11-21-2008, 08:55 PM   #1
Lincolnman's Avatar
Lincolnman is an unknown quantity at this point
Question Non-traditional screen resolution?
Alright, I am not sure how to start explaining this, but here goes.
I need to know if I can make the vertical resolution of my screen (future purchase) shrink by 1/4"?
To wit - I am looking at the purchase of an Asus eeePC to use as a base for my carputer. Specifically the model 900HA as seen here - http://www.newegg.com/Product/Produc...82E16834220441 . The problem arises in the fact that the screen's viewable portion is just BARELY smaller than the hole I have for it. Making the hole larger is not an option. The hole fits the screen's horizontal viewable portion PERFECTLY, but the vertical is 1/4" too tall. Argh.
So - what I need is a program, hack, or advice on how to basically ELIMINATE that 1/4" of the screen and have the rest of it squish into a smaller space. I don't mind if I wind up with a resolution of 900X600 instead of 1024X600 or something like that. The only real workable suggestion I have found so far is to just put it in and let it cover up the top bar of the windows, then right click from the taskbar to minimize, maximize, or close. I don't like that option and on top of that it mean that if I watch a video or the like full screen it cuts off that much of the action. So - I am not even sure how to go about this. I just need to effectively make the screen 1/4" smaller vertically.
Help?
Thanks in advance,
Lincolnman
Lincolnman is offline   Reply With Quote
Advertisement Sponsored links
Old 11-22-2008, 10:08 AM   #2
Lincolnman's Avatar
Found an old picture of basically what I am thinking. I 'shopped this image some time ago. In this picture the radio has been replaced with the screen, but in practice I have decided that it makes more sense to place the screen in the spot above it where the heater vent, wiper switch, lighter, and idiot lights are. The wiper switch will be relocated, the lighter eliminated, the vent blocked off so it just relies more on the other three in the dash, and the idiot lights will be incorporated into the OBDII conversion.
The radio will then be gutted and changed out to knobs only so that if I choose to run the carputer blind for music as though it were a regular radio I can. Left knob volume, right knob tuning/track, etcetera.
Anyway, this hole (the top one) is just shy of being 4.5 inches tall (required for full viewable area of the eee PC's 8.9" display), but dead on for width. I just need to know a way to convince the PC that it has a smaller height, wider ratio screen.
Also, hopefully it is now obvious why I will not cut the hole larger.
Old 11-22-2008, 10:15 AM   #3
Lincolnman's Avatar
Oops, see image.
Old 11-25-2008, 01:22 AM   #4
Haystack is on a distinguished road
why not just adjust it by narrowing it just like a regular old school crt?
Progress,.... that is what I keep forgetting ;)
planning_[++++++++++]. 110%
parts___[++++++----] around 60%
install___[-----------] -9,000%
Haystack is offline   Reply With Quote
Old 11-25-2008, 01:50 PM   #5
Lincolnman's Avatar
Perhaps I have not made clear that I am using the screen from the eee PC, not an aftermarket screen.
The eee PC (as they come) does not offer me the option of adjusting the screen beyond making the resolution worse. I can have the normal resolution or lower resolution, both completely filling the available screen space. I actually need it to not use the top (or bottom, either way) 1/4" of the display. They never made them to do this because they knew (or at least thought they did) that the screen would not ever be partly covered, so knowing what screen they would use the adjustment was apparently deemed unnecessary.
I read about making the screen a custom resolution somehwere through windows, but it was not suggested as it can cause problems, and I think that the method would just "stretch" the image back out to fit the screen rather than eliminating a section of the screen like I need.
Hence why I asked here - if it were just a straight adjustment I would not have bothered anyone.
Old 12-01-2008, 06:24 PM   #6
Lincolnman's Avatar
TO PUT THINGS MORE SIMPLY
I need to "window" all of my OS so that I am not using the top (or bottom, either way) 1/4" of the screen at all.
Does anyone have any idea how this ought to be done?
Old 12-02-2008, 12:27 AM   #7
hailrazer's Avatar
hailrazer is an unknown quantity at this point
Look up a program called PowerStrip.
It should do what you want.
My 2007 Yukon XL setup. http://www.mp3car.com/vbulletin/show...64-5000-a.html
hailrazer is offline   Reply With Quote
Old 12-03-2008, 11:43 AM   #8
Lincolnman's Avatar
Thank you, that looks as though it would do quite nicely.
I knew there had to be something, but I must have been searching for the wrong terms or some such. Thanks again!
Tags
resize, resolution, screen
FAQ: VGA vs. Composite (Video) Screens cproaudio The FAQ Emporium 2 12-28-2007 12:45 PM
any feedback info. on Dynamix 7" VGA Touch Screen TFT ??? xtreamvette LCD/Display 29 04-22-2007 04:19 PM
FAQ: LCD Technologies dontpntpool LCD/Display 4 03-15-2007 01:20 AM
Dell laptop, lilliput screen, and 800x480 resolution, possible? sivart321 LCD/Display 3 03-11-2005 11:46 AM
Newbie Question :-) About Screen Resolution jey001 LCD/Display 1 03-06-2005 10:33 AM
