Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 02-05-2009, 05:37 PM   #1
tusk is an unknown quantity at this point
2006 Infiniti G35 carputer woes...
My original plan was just to get a nice aftermarket NAV system that would go into the dash where my stock Bose system is. However, from what I'm finding you HAVE to buy a replacement console bezel...and this can only be found in plastic...mine is brushed aluminum, very nice looking.
So my next thought was just building a carputer where the LCD could just be mounted externally, or maybe in that cubby on the top. The one product I found that was apparently really great for this seems to be dead now.
Is there any way I can make a spiffy carputer setup with a touchscreen LCD in this car WITHOUT cutting it all up? One drilling or one small cut hole is ok, but anything beyond that is just above my skill level and far too much effort.
Any thoughts?
tusk is offline   Reply With Quote
Old 02-14-2009, 04:18 PM   #2
b3tts32's Avatar
b3tts32 is on a distinguished road
Have you checked ebay for their double din kits? I'm sure that will be your best bet to mount a 7" touchscreen. I'd check out g35driver.com to see what other people with your year model have done. I have an 04 and just bought the housing from here.
b3tts32 is offline   Reply With Quote
Old 02-14-2009, 05:49 PM   #3
It's ok, I found everything I needed. I'm actually going to do a post on it, because I have had a really hard time piecing all this information together for my 2006.
I found everything I needed at various sites, know exactly what a person DOES need, and how it looks. I didn't even know until I got the din-conversion that the finish piece had aluminum on the outside. I was just taking my chances. But it looks perfect, just like the original would look if it was made for double-din
Old 02-15-2009, 03:11 PM   #4
b3tts32's Avatar
Oh ok that sounds good. Have you decided where you're putting the pc? I'm going to shoot for the upper cubby spot above the glove box.
Old 02-15-2009, 03:27 PM   #5
Sorry, I wasn't clear. I was thinking this was the 6mt forum when you replied. I'm actually not doing a car computer now, I just purchased a Pioneer AVIC-F900BT instead. Of course, I still have the option later I guess to add a carputer to that setup. Though I'd have to use composite video or something which would be less than impressive :P
Tags
2006, carputer, computer, g35, infiniti
Carputer to stock audio. 1999 Infiniti I30 rlamb2 Car Audio 0 01-27-2009 05:45 PM
Help ... Want to add a carputer to an 03 infiniti Q45 qfour5 Newbie 8 01-25-2009 05:10 PM
OBDII Signal Splitter (for Infiniti G35) Caelric Engine Management, OBD-II, Engine Diagnostics, etc. 9 04-14-2007 09:32 PM
Carputer for Infiniti G35 Coupe chirowolf Show off your project 10 08-31-2006 08:18 PM
Infiniti I30 2001 carputer to factory system question... smokar Car Audio 3 12-03-2004 05:51 PM
