02-10-2009, 06:18 PM
#1
Mini amp question
Okay so I have been searching for mini amp and have only found 1 thing on it all the other search results are for mac mini's. Maybe there is another term for it. I am looking for the type of amp thats built into headunits so I don't have to rewire everything. All I can find is this http://www.mp3car.com/vbulletin/revi...0watt-amp.html . I really hope there is more mini amp selection.
02-11-2009, 02:55 PM
#2
Check this site out.
http://www.davidnavone.com/cart.asp?24&cat=5
Scroll down to the product called:
20 X 20 STEREO AMPLIFIERS
AMP-100 $39.99
I put one of these on a friend's motorcycle and he loves it.
2005 T-Bird, Via SP13000, Travla C158, M1-ATX, 1GB RAM, 120GB 2.5" drive, SlimSlot DVD-RW, XP, RR, Winamp, Xenarc 700TSV, HTC Touch PPC/Phone, BU-353 GPS/iG3, Elmscan OBDII, Griffin PowerMate, 2 Blaupunkt amps, Polk spkrs, 5 sec startup/S3 STR
~Jimmy
02-11-2009, 03:36 PM
#3
Hey, you're trying for the goal by going the other way around, you're crazzzyyyy!
OHHH, I use 4 motorcycle amps in my setup.... here is a link on ebay. http://cgi.ebay.com/2-CH-300W-MOTORC...3A1%7C294%3A50. They are called motorcycle amps, thats why you cant find them. The 4 I have are only 150 watts each, but only because I didnt need all that power. Either way, you will have to rewire stuff.
HiJack ZX1 CFSC
CAR PC ITEMS [ 35%]
INSTALL OF MULTI PC SYSTEM [ 35%]
BUG WORKOUT [ 0%]
INTERIOR MODS [ 45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Please build up my REP.
02-14-2009, 11:50 PM
#4
Now I could put them in the place where the stock head unit was and put the touch screen infront, or do you think it would get to hot? Its a 2x dimm
P.S.
Found this guy looks pretty good.
http://cgi.ebay.com/4CH-300-WATT-CAR...ayphotohosting
02-15-2009, 11:21 AM
#5
If you do decide to put them in the HU compartment, you have to come up with a really good cooling solution. These amps are small and dont have the large surface area of bigger amps so they can heat up alot when being used. I was going to suggest the 4 channel version, but they are really hard to find. When you get them, I would cut a hole in the top and mount fans. Only thing I am not sure of is to have the fans blow air away or towards the amps.
HiJack ZX1 CFSC
CAR PC ITEMS [ 35%]
BUG WORKOUT [ 0%]
HiJackZX1 Work Log
HiJackZX1 Website!
02-15-2009, 12:57 PM
#6
search for arc mini 125.2 very mini amp without sacrificing things like audio quality.
02-15-2009, 03:38 PM
#7
My idea was I would just wire it up near the stock wiring harness so they way when I sell the car I can just pull the mini amp out and wire the stock headunit back up.
02-16-2009, 01:51 AM
#8
You can do that, thats actually how I have mine. I bought a plug and play kit. Basically I wired the PC to the new wiring kit and it has a adapter that plugs into the cars current kit. That way I don't have to cut into the cars original wiring. All I do is press a small button and the adapter pops off, plug in the Head unit and I'm done. Although now this is pointless since I have heavily modified the car, I can never revert back to stock, unless I replace the whole dash from top to bottom.
HiJack ZX1 CFSC
CAR PC ITEMS [ 35%]
BUG WORKOUT [ 0%]
HiJackZX1 Work Log
HiJackZX1 Website!
02-18-2009, 04:37 PM
#9
Do you have a link to this kit HiJack. Damn I gave up on the CarPC. Looks like i'm going to start buying parts again heh.
| Thread Tools |
| Display Modes |
Linear Mode
