Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 05-14-2009, 09:10 PM   #31
eigenVector's Avatar
eigenVector is an unknown quantity at this point
Quote: Originally Posted by kross View Post
You're using the mo-co-so case? Those don't have great airflow. You can drill a bunch of holes directly over the CPU fan, to let some cool air in. Use some black Rustoleum spray paint so you don't see the holes as much after drilling.
Also, try running with the cover off of the case. This will tell you if the trunk is too hot, or just the air inside the case.
-- Kevin
No, I actually swapped the mo-co-so case out for a silverstone sg05-b because I couldn't find a heatsink that would fit the mo-co-so case. This silverstone has a nice big 120mm intake fan on the front of it, and lots of areas for ventilation on the sides. Plus I removed the AC/DC PSU box, so there's a big whole in the back where it used to be. The problem is most likely the hot air circulating in the trunk after sitting in the sun. There's lots of good airflow in the unit, but since the source of the air is hot, the circulation doesn't help much. I need to somehow get some cool air into the trunk (maybe tap into the AC, pull in some air from under the car, dunno, anything...)
The Opus PSU sits vertically to the one side where a PCI slot would be for an atx motherboard, and the power cables go out the rear of a PCI slot opening.
I need to modify my airflow diagram, because turns out the two CPU fans don't push air across (from right to left) like I had thought, they both push air out from the center (both blowing from the CPU out). So the only intake air is from the 120mm fan from the front of the case then out both sides of the CPU.
eigenVector is offline   Reply With Quote
Old 05-14-2009, 11:17 PM   #32
Hey, you're trying for the goal by going the other way around, you're crazzzyyyy!
HiJackZX1's Avatar
HiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really nice
You could do it this way.
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
INSTALL OF MULTI PC SYSTEM [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Please build up my REP.
HiJackZX1 is offline   Reply With Quote
Old 05-15-2009, 05:37 AM   #33
Yea, the guy I was talking to about this suggested creating some holes here in the rear dash, and suspending the pc case from the top of the trunk close to the holes.. This option is probably the best/easiest option I've heard so far.
Thanks!
Old 05-15-2009, 10:15 AM   #34
Here's an update to the diagram with updates to the airflow and CPU change.
Tags
amd phenom 9850, carpc, geforce 8200, power supply, zotac
AMD Geode NX1750 power requirements delturcious Newbie 0 10-16-2006 03:41 PM
FAQ: Will <insert PSU model> Power Supply work with my system? DarquePervert The FAQ Emporium 9 10-10-2006 01:38 PM
AMD based computer StreetStyleTT General Hardware Discussion 17 09-03-2005 05:57 AM
FS: ITPS shutdown controller and PW-70a MINI-ITX power supply hanzacra Classified Archive 4 08-07-2005 11:32 PM
DC-DC Car Power for Mac Mini MikeH MacCar 53 02-19-2005 01:13 PM
