Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 04-05-2009, 05:44 PM   #1
eigenVector's Avatar
eigenVector is an unknown quantity at this point
Question AMD Phenom 9850BE based CarPC
So I've got many old spare parts laying around (after a home system upgrade) and decided to go ahead and build a new toy for my car. After lots of research I came across this wonderful site called mp3car.com :O
Edit: After a lot of help and suggestions, here's the latest rundown on the components of this build:
Motherboard: Zotac GeForce 8200 mini-ITX
CPU: AMD Phenom 9850 Black Edition Quad Core 2.5Ghz 125W
Memory: 2x2Gb OCZ HPC Reaper DDR2 1066Mhz
Case: Silverstone Sugo SG05-B Mini-ITX Tower - *Updated*
Hard drive: 1x Western Digital Scorpio Black 320Gb - *Updated*
Power supply: Opus 360W Intelligent DC-DC PSU - *Updated*
Update:
Here's a diagram of the layout so far:
*Updated 20090515*
Thanks!
eigenVector is offline   Reply With Quote
Advertisement Sponsored links
Old 04-06-2009, 04:03 PM   #2
ioo
ioo is an unknown quantity at this point
You probably want the Opus, if your gonna run full-on desktop hardware. An M4 would prolly be fine power-wise, but Ive seen a lot of iffy reviews of it.
ioo is offline   Reply With Quote
Old 04-06-2009, 07:25 PM   #3
Thanks ioo, I think I will go ahead and opt out for an Opus. I guess I'll hijack this thread for future updates to this system as I build it.
Thanks again!
Old 04-07-2009, 07:22 AM   #4
wi77iam's Avatar
wi77iam
I'm also building my latest car PC with that Zotac 8200 board. IMO that Phenom is way overkill for the car, but whatever floats your boat. I'm putting an Athlon 5000+ in mine, and I'm underclocking it so I can run a M2-ATX. It will still be more than 4X faster than my old EPIA.
Good luck with the build.
wi77iam is offline   Reply With Quote
Old 04-07-2009, 09:14 AM   #5
strikeback03 is an unknown quantity at this point
Does that Zotec support the 125W TDP processors? I know some of those boards have issues with processors over 65W TDP. Also, the mo-co-so case only claims support for processors up to 45W TDP, so that Phenom would probably roast in there, no way to fit a large enough cooler.
strikeback03 is offline   Reply With Quote
Old 04-07-2009, 11:01 AM   #6
Thanks! I know it's overkill, but I upgraded my home box to a phenom ii (940) and now I have the 9850 sitting around collecting dust. I was debating whether to build a Media Center box, or go on out and venture into the car-pc world. This board should be good for both situations, and the car-pc seemed to be more of a challenge, which is why I decided to take this route.
According to the specs on newegg it supports phenom's. As to the 9850BE, I don't know. I've already got the board/cpu/memory so I can go ahead and put it together with a standard desktop psu to see if it has any problems booting/operating and let you know.
You're absolutely correct, I'm thinking about additional modifications to the case to support better ventilation. If all else fails, I'll resort to underclocking as wi77iam is planning to do. Will it be enough? I guess we'll find out.
Old 04-07-2009, 12:52 PM   #7
I can't find it at the moment, but there was an article on Anandtech about AMD motherboards (micro-ATX in that case) not supporting the 125W processors. They ended up blowing the power delivery systems of the motherboards. So if you are fine with possibly blowing the motherboard, might as well try it out. Zotec doesn't seem to have any documentation of what is qualified on the board.
Old 04-07-2009, 01:33 PM   #8
I'll definantly keep my eyes open for this, but I just came across this list of supported CPUs for this motherboard on zotac's site.
http://www.zotac.com/httpdocs/brochu...rce%208200.txt I'm curious as the Phenom I chips listed here are 95W, but their Phenom II 940 chip is a 125W chip. Because of this, should I put my 940 on my car pc, and leave the 9850 in the desktop? Seems more than overkill, but does it make sense that it would be able to handle the 125W Phenom II 940, and not the 125W Phenom 9850BE?
And after even further reading, the Zotac brochure lists "65-watt TDP recommended"
Perhaps this may not be the best of ideas after all :/
Edit: They updated the cpu compatibility list yesterday for this board, and added the 9850 and 9950BE to the list. Still odd how they support it, but recommend 65-watt tdp cpus.
I'm gonna give it a go anyways.
Last edited by eigenVector; 04-08-2009 at 07:19 AM. Reason: Update to zotac's list of supported cpus
Old 04-17-2009, 09:17 PM   #9
The mo-co-so case came in today! Quite impressed by the work that has gone into it too.
However, as I suspected, the stock hsf for my cpu is too big for my case. I've been researching some that are on the market, and was wondering if anyone has any thoughts on the best cooling solution for this case.
Currently I'm leaning towards the 60mm Arctic Cooling Low Profile CPU Cooler. And as best as my measurements are, I think this should fit, but it'll be tight.
Anyone have any other suggestions?
Old 04-18-2009, 03:48 PM   #10
Hey, you're trying for the goal by going the other way around, you're crazzzyyyy!
HiJackZX1's Avatar
HiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really nice
HOLY F*C%in $H!+, a QUAD CORE!!!!!!!!!!!! OMG, and so many people say DUAL CORE is over kill. Have you tried a power consumption calculator? I dont think even a OPUS will work, dont Quad Cores need more then 500 Watts to work?! If you do make this happen I cant wait to see it.
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
INSTALL OF MULTI PC SYSTEM [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Please build up my REP.
HiJackZX1 is offline   Reply With Quote
Old 04-18-2009, 04:00 PM   #11
Yea, I know I'm pushing a huge wall here. According to one review, this CPU under load requires 256Watts (154 Normal). Another review claims 300W under load (199W idle). I went ahead and purchased the Opus 360W, and am hoping it will suffice. Otherwise I don't have any problems under clocking the CPU.
I'm not even planning on adding any display to this PC either, so I don't have to worry about it taking power. I'll be using my windows mobile phone as a display. I have no plans for any additional USB peripherals, except a place where I can connect my phone for charging/syncing.
Old 04-18-2009, 05:53 PM   #12
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Yes, a quad-core is overkill.
However your odea on the power needs is off. The Pehenom II quad-cores suck down 95-125w, which is comparable to other performance-oriented CPUs.
That said, I don't think a CPU drawing that much power is the best choice or a vehicle install.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 04-18-2009, 07:51 PM   #13
Are you suggesting a system that pulls that much power for a vehicle will cause the vehicle itself to suffer from a lack of power? If that is the case, is there anything that I can/should do on the alternator side to make sure that the car will have adequate power because I'm only using a factory alternator on my '05 grand-am?
The reason I'm going quad core, is not because I require the performance of such a processor, it's simply because I've got one lying around. 'Over-kill' (whatever that actually means technically speaking) or not, at this point in the build I'm looking for a system that will collect gps data (Migrating from a custom piece of software I built for my windows mobile phone), collect OBD-II data, and provide audio to my car stereo. Do I have the components required for this? I think so.
Moderators: it appears I have a missing post between #10 and #11. Is it because I included a hyperlink in it? I know I'm new here and all, but how long does this 'probationary period' last?
Old 04-18-2009, 08:02 PM   #14
It ain't easy being a green moderator
meddler's Avatar
Location: Steps out the front of Henson's workshop or Sydney
meddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud of
Your post was awaiting moderation. You should be ok from now on.
Chat on the mp3car channel on IRC
Server: efnet Channel: #mp3car
No irc client installed? Go to http://chat.efnet.org/. In the channel drop down box select "other" and type in #mp3car.
meddler is offline   Reply With Quote
Old 04-18-2009, 08:19 PM   #15
Thanks! And OOOH, an IRC Channel!
Tags
amd phenom 9850, carpc, geforce 8200, power supply, zotac
AMD Geode NX1750 power requirements delturcious Newbie 0 10-16-2006 03:41 PM
FAQ: Will <insert PSU model> Power Supply work with my system? DarquePervert The FAQ Emporium 9 10-10-2006 01:38 PM
AMD based computer StreetStyleTT General Hardware Discussion 17 09-03-2005 05:57 AM
FS: ITPS shutdown controller and PW-70a MINI-ITX power supply hanzacra Classified Archive 4 08-07-2005 11:32 PM
DC-DC Car Power for Mac Mini MikeH MacCar 53 02-19-2005 01:13 PM
