Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 06-11-2009, 12:59 AM   #1
moelsaied88 is an unknown quantity at this point
GPS/XM sharkfin antenna (i really did search)
Hello guys, im nearing completion of my carpc, now im just looking for an antenna that can multi task. Ive been going crazy googleing and searching mp3car. Hopefully all you geniuses can help me. I am looking for a sharkfin style antenna that can do gps and xm. If it can do anything else it would be awesome, but those 2 are my main concern. I saw the antenna that is on mp3store but it doesnt have XM. also if someone can point me in the direction of a gps reciever with capable external antenna that works with centrafuse i would greatly greatly appreciate it!! Thanks again! (and i swear i really did search but could find nothing that pertained to making a new antenna and not using oem or just stuffing the BU353 into a dummy)
moelsaied88 is offline   Reply With Quote
Old 06-11-2009, 03:32 AM   #2
Crinos is an unknown quantity at this point
I have not been through it all, but http://www.badland.co.uk/products.php might have something for you?
Or you could go for the real deal.. buying the BMW antenna:
Follow this link: http://www.realoem.com/bmw/showparts...40&hg=65&fg=30 to find what partnumber you want, and then go to your local Bavaria/BMW dealer and order it.
GSM, GPS and DAB Radio... (and if I'm not mistaken, you ca use the DAB part for your XM).
Crinos is offline   Reply With Quote
Old 06-11-2009, 11:37 AM   #3
thank you so much for your help!!! i really really appreciate it. if i could trouble you for one more thing, do you have any recommendations for a gps receiver that can connect to the sharkfin and is compatible with centrafuse? ive been looking for a guide to convert DAB to XM but i cant seem to find anything. Is it a straight connect and DAB is just another name for XM/Sirius? or is there more to it? thanks in advance!
Old 06-11-2009, 12:32 PM   #4
a2carat is an unknown quantity at this point
I recently did this..... i bought one of those dummy shark fin for VW opened it up and put my bu-353 in and my xm antenna, I get crappy reception from the xm antenna but i think it was from the twisting and testing the antenna on the base
the xm (little one ) its upside down....
a2carat is offline   Reply With Quote
Old 06-11-2009, 05:25 PM   #5
Maheriano will become famous soon enoughMaheriano will become famous soon enough
Can someone explain to me what exactly you're doing here? How do you get the USB cable from the antenna to your computer to send the signal? Is it wireless?
Ampie Case
256 MB DDR2 PC5400
Xenarc 700TSV - VGA Monitor
Intel D945GCLF Motherboard
M2-ATX-HV
2005 Honda Civic
Maheriano is offline   Reply With Quote
Old 06-11-2009, 09:31 PM   #6
in that pic the gps is disconnected thats why there is no cable.. the connector its small enough that fits through the opening of the antenna. now the xm antenna I had to cut it in order to pass the cable through the opening..
and then just run the cable to the carputer which is the trunk so its not a long run for the cable
sorry I only took that pic..
Old 06-15-2009, 12:46 PM   #7
does this stay waterproof? im worried if i do this i might damage the antennas. also what gps receiver are you using? I bought the bu 353 cuz it seems to be the most popular one
Old 06-15-2009, 01:18 PM   #8
its been raining a lot down here in florida and everything its still working fine it has a rubber that goes between the car and the antenna that prevents water from going in into the bottom of the antenna.
my gps its that same one you have the bu-353 I took it out of the enclosure that it has and put inside.
Old 06-15-2009, 01:41 PM   #9
can i ask you one last thing, where did u get the dummy fin? ive been looking at the ones on ebay, the ones that look more like bmw's but there doesnt seem to be enough room underneath for adding anything. im afraid to buy it and figure out it doesnt really fit
Old 06-15-2009, 11:08 PM   #10
just search for "vw shark fin" the one i bought had the am/fm antenna in it but i took it out b/c it did not fit with the others and I hardly use it anyways
Old 06-18-2009, 09:29 AM   #11
strikeback03 is an unknown quantity at this point
My BU-353 works perfectly hidden under my dash. So I only have the standard XM antenna on the roof, as it does not works so well inside the car.
strikeback03 is offline   Reply With Quote
Old 08-11-2009, 12:05 AM   #12
maxxx is an unknown quantity at this point
To clarify, does the DAB feature work as a Sirius antenna? Is there somewhere where we can see what the connectors look like? i would like to hook up my Alpine N872A nav and Alpine sirius tuner to one antenna on the roof if posible, not opposed to using BMW hardware, if it is plug-and-play
maxxx is offline   Reply With Quote
Old 08-11-2009, 12:36 PM   #13
I was wondering more about cutting a hole in the roof of the car, not the antenna.
Ampie Case
256 MB DDR2 PC5400
M2-ATX-HV
2005 Honda Civic
Old 10-09-2009, 05:57 AM   #14
pilotghost is an unknown quantity at this point
Thumbs up GPS/XM sharkfin antenna
If you don't want to make a hole first try an antenna to fit inside your car attached to the window inside, for example something like this antenna GPS Combined - 2J620P
WIFI / BLUETOOTH 2.4 GHz / AMPS 824-894MHz / UMTS 2.1 GHz / GSM 900 MHz / GPS 1575.42 MHz / DCS 1900 MHz / PCN 1800 MHz
But if you don't have much time to play around just go some car repairs shop and ask them to make the installation for you and attach one of this to your car, they have a great performance and they look great, I have one of those in my vehicle!
"Shark" GPS/GPS 1575.42 MHz/Glonass 1572MHz to 1610MHz/GSM/WIFI antenna
I hope you have your mind a bit more clear now
pilotghost is offline   Reply With Quote
Advertisement Sponsored links
Accommodating my GPS and WiFi antenna portabuddy Fabrication 7 11-26-2006 03:25 PM
Search quirk? Silentbob343 Road Runner 4 02-02-2006 09:48 PM
EBAY: Vauxhall n Other SHARKFIN AERIAL 'REAL' - FM/AM ANTENNA ccsnet Classified Archive 0 08-22-2005 10:06 AM
