Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 06-16-2009, 01:20 AM   #1
xyz9915 is an unknown quantity at this point
LM555 as variable frequency oscillator
Hello!
I need a circuit in which the frequency of LM555 astable multivibrator can be controlled externally I mean by the help of transistor etc. So, please guide what modification may be done in the attached circuit
xyz9915 is offline   Reply With Quote
Old 06-16-2009, 01:48 AM   #2
What can I say? I like serial.
Curiosity's Avatar
Curiosity will become famous soon enough
What's the ultimate goal?
What will it control?
What will control it?
A set of predefined speeds or variable?
XPort 1.41 -GPS port splitter, logger, and USB device resume fix
GPS DirectShow Filter / XOBD / MiniCam
Curiosity is offline   Reply With Quote
Old 06-16-2009, 09:57 AM   #3
Actually I want to control the frequency by the help of R2R (ladder network), where the digital input value will increase/decrease the DC voltage of R2R network, so the frequency may be varied from 1Hz to 5Khz (i.e. My desired frequency). So what should I do?
Old 06-16-2009, 01:07 PM   #4
Curiosity's Avatar
That's a pretty wide range. Tone generator? You could always use a potentiometer for manual selection or digital pot for some other input. For momentary R2R, do it like steering wheel controls (each pushbutton and resistor in series). You probably already thought of that. Switching in sequence, maybe a NAND gate (google LED chaser circuit).
Variable syntax questions Iamthehor FB Software 14 02-25-2009 10:58 PM
radioshark and AMP Fallout AMP 6 10-08-2007 03:15 PM
Getting current frequency from Radiator portreathbeach Software & Software Development 1 11-28-2006 04:50 PM
found in fperrorlog 510SX FP Bug Reports 3 09-21-2006 09:01 AM
yet another frodo install with problems. Marsupial FrodoPlayer 10 08-27-2004 07:28 AM
