Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 06-30-2009, 10:06 PM   #1
HumungousBacon's Avatar
HumungousBacon can only hope to improve
Touchscreen not working????
Ok so ive got this motherboard.
VIA EPIA-800 mini-ITX Motherboard
Includes embedded VIA C3 800MHz CPU, 10/100 Ethernet, TV Out, AC'97, USB1.1, UltraDMA 100.
Why won't touchscreen on my lilliput eby701 work. video works but no touch
HumungousBacon is offline   Reply With Quote
Old 06-30-2009, 10:19 PM   #2
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
did you install the drivers? did you plug in the USB cable? Does it even enumerate in the device manager? Did you calibrate it?
Really we need more info here...
Old 06-30-2009, 11:48 PM   #3
nevermind lol i got it.. go ahead and delete this thread
Old 07-01-2009, 02:09 AM   #4
hairyMerkin is an unknown quantity at this point
I bet he didn't plug in the usb cable haha
hairyMerkin is offline   Reply With Quote
Old 07-01-2009, 02:33 AM   #5
robert1961 is an unknown quantity at this point
i am having same problum .. have tc-1000 with lilliput incar touchscreen monitor .. the motherboard went down so put a intel atom board in d945gclf..works great ..but under xp and windows 7 .there's no driver software in touchkit used lilliput and other stuff still same all usb ports work even tried changing com port 1 to 2 to 3 to 4 ..nothing ....am i doing somthing wrong ????? thank you for your help
robert1961 is offline   Reply With Quote
Old 07-01-2009, 06:26 AM   #6
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
USe the Vista drivers for Windows7.
And type in whole sentences. People will understand you better.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 07-01-2009, 05:04 PM   #7
no everything was hooked up right...
Old 07-01-2009, 06:07 PM   #8
2k1Toaster's Avatar
so it just magically started working via voodoo?
Old 07-01-2009, 07:25 PM   #9
i guess lol i didnt change anything........
Old 07-16-2009, 06:52 PM   #10
alejoal07 is an unknown quantity at this point
I'm having a problem with my new eby701, video works great but the touch panel is not working... i installed the drivers and when i plugged the usb... nothing happened?!
its like i didnt conect anything to the pc because it doesnt even show in the device manager...?
Help !
thank you
alejoal07 is offline   Reply With Quote
Old 07-16-2009, 11:37 PM   #11
check to make sure the two ribbon cables are all the way in tight
Old 07-17-2009, 03:09 PM   #12
wouldnt opening the screen void my warranty?
Old 07-17-2009, 05:40 PM   #13
2k1Toaster's Avatar
Yep indeed. But you have to do so any way to mount it usually.
Old 07-17-2009, 06:59 PM   #14
yes but you wouldnt mount it if you knew it's not working and you can get a replacement from the seller...
anyways i talked to the seller he's shiping me a set of new cables and if that doesnt work he will replace it with a new one so... its all good now
thanks for the help
Help! Touchscreen not working Stealth915 LCD/Display 10 07-09-2008 05:12 PM
Touchscreen install not working Skipjacks Input Devices 1 10-02-2007 08:43 AM
Touchscreen not working Ascension LCD/Display 5 06-01-2005 12:14 PM
Touchscreen problems with nlite and minlogon Ascension WinNT Based 1 06-01-2005 06:18 AM
Honda factory touchscreen to get DVD working? gadget Newbie 1 04-27-2005 04:53 AM
