Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 07-11-2009, 01:01 AM   #1
danimal is an unknown quantity at this point
Starts to boot then Nothing?
Finnaly attempted to boot my car PC today. Put my psu in standard ATX mode and attemted to boot my carputer....
Power and HD LED illuminate processor fan starts, after no more than one second all stops and nothing.
I have 12 volts at inputs
Running a AMD Sempron 3300 with standard 160 G HD, 526 RAM, and standard VGA monitor for test.
Using M4-ATX power supply
danimal is offline   Reply With Quote
Old 07-11-2009, 01:13 AM   #2
csfile's Avatar
csfile is on a distinguished road
Do you get POST? Or any beep codes?
Does the AMD Sempron need the 4 pin 12V power connector? If so, is that connected?
Also start by checking if the RAM is good. Then start testing other components by swapping them out with other components (swap in a different power supply or try the power supply on a working PC).
csfile is offline   Reply With Quote
Old 07-11-2009, 11:03 AM   #3
Ok ive hooked up the astandard ATX power supply and it boots and runs..
Any ideas?
Old 07-11-2009, 01:37 PM   #4
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
make sure the connector on your pwr pins isnt reversed. thats what it sounds like to me
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 07-11-2009, 04:25 PM   #5
ill give it a try, though i did put the M4 power supply in stadard ATX mode and use the actual power switch from the desktop in the same place as it was in when i booted it with the actual standard ATX AC-DC PSU. When using the AC-DC it booted fine, but when using the 12V from the AC-DC to power the M4 i got a simple flicker of the power light and a rotation of the fan and then nothing. that was useing the power on from the M4
Old 07-13-2009, 12:17 AM   #6
Fixed the issue, PSU wasnt putting out enough amperage on the 12V rail put it on my cars batter booted up perfect, cut the ACC and shut down without a hitch. SO RELIVED
Speed up boot with buried features in msconfig Injector Operating System Optimization 23 06-25-2009 03:19 PM
"verifying dmi pool data" dougbrooks Newbie 3 08-15-2006 11:09 PM
comp won't boot with USB to IDE dvd rom plugged in mjs3350 General Hardware Discussion 6 08-12-2006 04:57 AM
Help! Monitor (PC to Avic-N1 via RCA) won't display anything after boot up screen! lil' is 300 General Hardware Discussion 6 04-09-2006 03:23 PM
Oh where have all the Shutdown Controllers gone (and boot time)? SuperAJ General Hardware Discussion 17 05-21-2005 10:57 PM
