Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 07-22-2009, 06:35 PM   #1
danimal is an unknown quantity at this point
Can I Change CPU and MOBO while not reinstaling OS
I want to change from a ATX to MINI ITX, the board i found comes with Intel Core Duo T2500 2GHz 2M 667 SL8VP Processor, though i was previously using a AMD processor, so I was hoping that i could switch over my HD with the OS instaled on it to the new board and CPU and be ok, then i thought, yea right nothings ever easy.
If you could help me out id greatly appreciate it.
danimal is offline   Reply With Quote
Old 07-22-2009, 06:55 PM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
No.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 07-22-2009, 07:12 PM   #3
duster's Avatar
duster is an unknown quantity at this point
as a tech I would say no, as the driver files are scattered throughout the registry and each board uses different and also similar chipsets which will casuse many issue all of which untroubleshootable. Most of them deal with the HAL which is a core component of windows this area never moves and other drivers get placed next to it. this doubling effect will cause less resource availability which some drivers and hardware will not share these resources and the BSOD will start happening. keep in mind some of this info is simplified but the core concept is there. As a side note there are repair installs but that is about as effective as fluffing your pillow it may work but it will go flat again in the near future or worse. As a rule of thumb if you want the most stable system dont be lazy do the work and keep your sanity.
duster is offline   Reply With Quote
Old 07-22-2009, 07:21 PM   #4
LordKaT is on a distinguished road
Depending on the OS you're using, changing the CPU and motherboard out might force you to get another license (windows XP and up), though that can usually be sorted out with a not-so-quick call to tech support.
Technically, you CAN change the motherboard and processor without reinstalling the OS. I've actually done this exact procedure a couple of times under Windows and once under Slackware. It's a huge PITA though as you'll probably end up reinstalling the OS after the 75th inexplicable bluescreen or kernel panic.
For the sake of your own sanity, I'd highly recommend a fresh install after swapping out a lot of major components.
LordKaT is offline   Reply With Quote
Old 07-22-2009, 07:27 PM   #5
duster's Avatar
I see this question day in and day out dont get me wrong I have done it before but not often, normally within weeks you will have issues. And I have also done it to see if I could force it typically with the time wasted you can install and fully configure a new system, plus normally with a carry over os you end up reinstalling again anyways so you waste 4 times the time of a normal reinstall
Old 07-22-2009, 07:30 PM   #6
haha alright, i was just wondering seeing as i went through this whole process last week and was hoping i wouldnt have to do it again.
So i should install the new MoBo and CPU then reinstall the OS?
Old 07-22-2009, 07:58 PM   #7
duster's Avatar
I typically will install the board and hardware then install on a new hard drive and then pull data off the old drive as a data drive being that this is a week old there is not much data to worry about ... I would just install the hardware and the use windows install cd to nuke the system and start from scratch.
Old 07-22-2009, 08:09 PM   #8
North of the land of Hey Huns
malcom2073's Avatar
malcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to all
Using linux: Yes.
Using windows: no.
RevFE - Try it, you just might like it.
Carbon - Next Generation Touchscreen Browser
Come join us on IRC: irc.efnet.net #mp3car
Audiophiles make me chuckle as they pad my wallet.
malcom2073 is offline   Reply With Quote
Old 07-22-2009, 08:16 PM   #9
so the reinstall will reconize the hardware changes on its own and make the appropriate changes?
Old 07-22-2009, 08:28 PM   #10
malcom2073's Avatar
Nope. On linux you have to make the changes if any are even required (I've never had to make anything besides occasionally display changes), but the difference is that linux allows you to make the changes instead of (most of the time) blue screening so you can't even boot into windows.
Old 07-22-2009, 08:30 PM   #11
Mehh im using windows curently
Old 07-22-2009, 08:46 PM   #12
justchat_1 will become famous soon enough
On win7 you can....
openMobile - An open source C# Front End
- Currently Recruiting Developers -
Available for download on sourceforge
justchat_1 is offline   Reply With Quote
Old 07-22-2009, 08:55 PM   #13
Punky is on a distinguished road
last time i checked, Achronis was able to do this. Though I have never tried it.
Punky is offline   Reply With Quote
Old 07-23-2009, 10:11 AM   #14
soundman98's Avatar
soundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the rough
Quote: Originally Posted by justchat_1 View Post
On win7 you can....
ot question: what makes windows 7 different that would allow for that?
like everyone else said, it is easier to just reload the entire computer-- i have replaced mo.bo.'s with the exact same model and reused the processor and memory, sometimes you can get away with it, but most of the time you can't.
soundman98 is offline   Reply With Quote
Old 07-23-2009, 10:22 AM   #15
Super Moderator & Wal-Mart Greeter
Tidder's Avatar
Tidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant future
Yes you can. It's a fairly difficult process if you don't know how to manually install drivers. However it's very possible and pretty easy if you do. All you need to do is install the drivers for the new motherboard before you swap them. The biggest one is usually chipset and drive controller, but I typically do it all. Sound, video, chipset, CPU, hdd controller, etc. If you can do that, you're good to go. I've done this process quite a few times when upgrading hardware in a server 2003 box, and a couple times with XP. The process has worked for me 100% of the time on servers, and out of the 7 or 8 times I've done it with XP I've had it not work only once iirc.
The biggest difference between windows and linux is that linux does this automatically. The drivers are all built into the kernel, whereas with windows it loads the drivers it needs during install and forgets the rest.
Also, sometimes the ENUM key has to be deleted out of the registry, reboot, and do a manual detection of hardware. This used to be THE way to do it in win98, but it works with XP as well.
Tidder
Try RevFE
The best frontend I've ever used, period.
Best Quote EVER!!
Quote: Originally Posted by bramlet View Post
I try to search but I usually only find posts where people ask questions and darquepervert tells them to search.
Tidder is offline   Reply With Quote
Help figuring out what's up... mobo, CPU, memory, or PS jmbickham General Hardware Discussion 6 01-02-2009 07:18 PM
Testing the waters: mini itx p4 mobo and cpu EsKALad Classified Archive 15 12-31-2005 10:46 PM
Mobo, CPU and power rail MatrixPC General Hardware Discussion 0 11-15-2004 10:19 AM
FS: mobo, power supply, CPU etc just look! dannn Classified Archive 1 11-01-2004 10:52 PM
Brand New Mobo and 2.53 Celeron CPU CJ8501 Classified Archive 12 09-30-2004 08:16 PM
