Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 09-22-2009, 08:07 AM   #1
smilykoch is an unknown quantity at this point
Code immobilizer?
Hey..
I was wondering if it is possible to make a software/hardware solution for a carpc that does the following? :
When you put your key in your car and turns on ignition power the carpc turns on, the first screen you see would be a screen with 0-9 and somthing like "submit" and "C" - you would then need to press a 4 digit code right to deactivate the immobilizer and the screen would continue to something like CF frontpage.
So it would require the 4 digit code to be right before you can start the car? and then something like 3 wrong tries would require you to wait like 10 min before you can start again ?
It would be really cool..
you know.. i mean like, fx some pug 106 has the code part of it, but just not in the carpc..?
Hope you will be able to help me out here..
(know its not newbie, but dident know where to drop the post..)
Smilykoch.
smilykoch is offline   Reply With Quote
Old 09-22-2009, 08:19 AM   #2
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
This is possible but the question is whether or not you want to trust it. Several issues:
1. If the PC doesn't start, you car doesn't start. This WILL happen to you.
2. Unless the PC is on standby, startup times are around a minute. You can probably get that down to perhaps 20 seconds, maybe a little less. Do you want to wait that long?
3. In a low battery situation, your PC will suck a lot of juice that could be used for starting. This could easily happen in the winter if your battery is older.
4. Your PC will need to survive crank every time to make sure the car doesn't shut off when starting.
These are not insurmountable problems but I'd bet money there will be times when your car will strand you somewhere. Most likely on an important work day when you have a presentation to the higher ups.
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 09-22-2009, 08:28 AM   #3
hmmm... okay, i see what you mean..
The nr 2 i have no probs with, the carpc is connected to my central lock, so when i unlock the doors the carpc starts, so its nearly fully started when i am in the car..
The nr 3 also, i have an extra battery because i have a pretty big power use ;b hehe..
I see the nr 1.. :s wouldn't it be possible to make some sort of safety for this, something like being able to work around the carpc if it doesn't start ? an extra keyboard with 0-9 ? or just a plug to plug the keyboard in?
What do you mean with nr 4? didn't quite understand? ;o
Old 09-22-2009, 09:53 PM   #4
Bugbyte's Avatar
When you start the car (that is, crank the starter) the voltage drops considerably. Modern intelligent DC-DC power supplies attempt to compensate for this but it is still possible for the voltage to drop too low to keep the PC alive when you crank the starter. The PC will restart just like you pressed the reset switch.
Depending on how the immobilizer system is designed, this could cause your car to shut off.
Want to:
-Where is the iBug?
Old 09-22-2009, 09:59 PM   #5
North of the land of Hey Huns
malcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to all
If you want to do something like that, personally I'd buy a serially controlled graphical touchscreen, and run it off a microcontroller. Take the PC entirely out of the loop. a Carputer is not something you want to trust with your life (what if you had to get to the hospital?), or even your job (Sorry boss I was late, my car wouldn't let me start it) with. It's a cool idea, but using a PC is just impractical. You're adding levels of failure to an already fragile system.
RevFE - Try it, you just might like it.
Carbon - Next Generation Touchscreen Browser
Come join us on IRC: irc.efnet.net #mp3car
Audiophiles make me chuckle as they pad my wallet.
malcom2073 is offline   Reply With Quote
Old 09-23-2009, 02:39 AM   #6
serially controlled graphical touchscreen?? perhaps a link? how does that system works and would i still be able to run the carpc on that screen after the car has started ? or would it be a second screen ?
Ahh.. i see the problem with the voltage.. :s not that cool.. any ideas on how to make the system work so i could make something like this.. (its just an idea, i just wanted to know if its possible. And how? so any solutions on how to solve those problems properly?)
Old 09-23-2009, 05:44 AM   #7
justchat_1 will become famous soon enough
Use a latching relay with a hidden override button. If the crank voltage drop causes the PC to reboot the car will stay running. In the event things go wrong you'll have that hidden button you can use to still be able to get where you need to go.
ediit:
and for obvious safety reasons this type of system should be tied into the start circuit not the run circuit.
openMobile - An open source C# Front End
- Currently Recruiting Developers -
Available for download on sourceforge
justchat_1 is offline   Reply With Quote
Old 09-23-2009, 05:53 AM   #8
okay.. so you would just insert a relay and then make the software so the relay is only active when the code is pressed right..? in that way you could still use a normal car alarm with it.. then just put the relay on the car start circuit ? would that work?
Old 09-24-2009, 04:46 PM   #9
black_mamba is on a distinguished road
Just like justchat said. Use a relay that will bypass the computer and just hide the switch for it. If, for any reason, the computer is not working, just hold the switch that will turn on the relay that bypasses the computer. How you setup the relay would totally depend on how your immobilzer is designed (though I think most are just a relay themselves). I've never used an "immobilzer" product before, so I don't know how they work, but I have installed more than my share of car alarms and stereos to know that this is easy enough.
If you have a link to the immobilzer you are thinking of using that might give more insight as to what can be done with it.
black_mamba is offline   Reply With Quote
Old 09-24-2009, 04:52 PM   #10
Yes thats the basic idea...
My comment was about using a latching relay....latching relays have an on pulse and an off pulse instead of constant power to keep them switched. This means when the computer sends the on-pulse even if the computer shuts off right after, the car can still be started. Then when the computer is shutting down it sends the off pulse to the relay to immobilize the car again.
Old 09-24-2009, 05:15 PM   #11
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
As far as Software goes, Access Control does they keycode thing.
It can also record Audio from a mic or/and Video from a camera.
It can also be used with some Microsoft Fingerprint scanners.
Has up to 10 user PIN numbers with different actions settable for each one.
Different programs can be run on unsuccesful key entry.
Has user settable number of tries.
You would just need to have a program to trigger a relay or something to do the hardware bit.
Enforcer is offline   Reply With Quote
Old 09-25-2009, 04:17 AM   #12
okay sounds nice.. i was thinking of using a LEA825 alarm and then with this trick, mostly just for the gadget part of it ;p
Then i had in min using phidgets for the hardware part, the latching relay sounds like at really nice idea..
Also does the Access Control sound nice.. then i just need to make CF plugin to make it start before the CF main page is showed or how ?
Old 09-25-2009, 04:26 AM   #13
ohh btw.. do you have a link for the Access Control ?
Old 09-25-2009, 04:27 AM   #14
nvm.. found it in your avatar thingie under your post ;p
Old 09-25-2009, 04:45 AM   #15
only one prob enforcer ? your download link is dead ? ;p
Tags
carpc, code, immobilizer, touch
unlock code slrpro02 Wireless Communications 2 12-28-2007 06:55 PM
Source code bugged Saldorri Media Engine 0 07-29-2005 09:23 AM
Head Unit 'code' - help! Laidback Car Audio 41 06-10-2005 09:53 AM
