Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 11-01-2009, 04:29 PM   #1
redbeauty2012 is an unknown quantity at this point
N00b help with laptop setup
I have an old laptop that I want to use with a carpc with a 7" touch screen lcd. i know that i need to run a vga cord to the laptop from the screen. how do i get the sound to work. i have a pioneer deck in my car now. what do i need in order for this to work. i read somewhere like rca from the headunit to the laptop. any responces are appreciated. thanks!
redbeauty2012 is offline   Reply With Quote
Old 11-01-2009, 05:12 PM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
http://www.mp3car.com/vbulletin/advfaq.php
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 11-01-2009, 10:09 PM   #3
i went there and couldnt find what i need i am using a laptop that will be removed after each use and i want to use the jack in the front. any diagrams or can anyone point towards a thread that talks about this?
Old 11-02-2009, 07:02 AM   #4
If you couldn't find the answer to this question in the FAQs, then you're not looking very hard.
I will link you directly to the FAQ that answers your question: http://www.mp3car.com/vbulletin/advf...iew&advfaqid=7
Old 11-02-2009, 07:21 AM   #5
what i wanted to know is if the aux in is the headphone jack on the computer or is it somewhere else
Old 11-02-2009, 10:58 AM   #6
soundman98's Avatar
soundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the rough
every computer and head unit is completely different. for some computers, you can change what the output jack is assigned to, others, you can't. some head units have aux in's, or support a add-on module that will take a aux in, and some models don't.
i re-read your responses a couple of times and think that darques answer was more than adequate(sp?), being that you originally asked only how to connect the computer to your stereo.
you will need to give us model numbers for the equipment:
generic info: most laptops have a headphone jack output-- use this for sound.
if your pioneer head unit does not have a front or rear aux input, the only ones that you can add one to will be ones with model numbers starting with DEH-P_ _ _ _. any other models will not support pioneers P-bus adapters.
soundman98 is offline   Reply With Quote
Old 11-02-2009, 12:07 PM   #7
The headphone jack on the laptop is an OUTPUT.
It would go to the auxilliary INPUT on your headunit.
Old 11-02-2009, 03:42 PM   #8
That answers what I was looking for thanks. I do have aux input on my headunit just didn't know if the headphone jack would work. I am new to this kind of stuff so hopefully I will get better in the future.
Old 11-02-2009, 10:16 PM   #9
alright another problem i ran into... i have been searching to find out a way to autopower on my laptop with a switch/button/etc... when it comes to the part where you solder the two pins on the power button i am completely lost. how do you know which pins to solder i saw something about closing but not understanding.
Old 11-03-2009, 06:39 AM   #10
And that is why laptop installs are more of a PITA than desktop installs.
You have to do some research into your make/model of laptop to find schematics and other documentation to find what you need.
I'd start with the manufacturer's website.
Other options are using WoL or WoR.
If your laptop supports resume from a USB device, that may be another option.
Old 11-03-2009, 11:46 AM   #11
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
The way you can test this is to use a digital multimeter and check for continuity across the pins, then press the button and see if you get continuity. If you do, those are the pins.
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 11-03-2009, 07:03 PM   #12
for power would a charger that plugs into the cigarette lighter work? or would it not have enough power/be dangerous? i am going to take the laptop out everyday and charge it during the night and just need something to charge it if i absolutely need it.
Old 11-04-2009, 09:24 AM   #13
soundman98's Avatar
it should work ok. if you are going to use a inverter, and then use the power cord that came with the laptop, you might run into noise issues from the inverter-- but the only way to know would be to try it and if you do have noise problems, look at solutions at that point
New Laptop Project! LeeVD Laptops, Netbooks, Tablets, UMPCs, etc. 3 11-22-2007 01:59 PM
What could cause this problem? (laptop related) Rocky388 Laptops, Netbooks, Tablets, UMPCs, etc. 5 09-17-2006 04:17 PM
COMPAQ laptop setup omlax19 Classified Archive 6 08-03-2005 12:08 PM
can you use a laptop screen for a mp3car setup? brandondere General Hardware Discussion 8 03-21-2001 10:41 AM
