Quote: Originally Posted by
patsfanwilly
My question is should i still put a fuse holder close to the battery or after the distribution block.
Yes and yes.
The fuse near the battery will protect the wire from the battery to the distro block.
The fuse after the distro block will protect the wire from the distro block to the equipment.
In your case, the distro block has fuses for the wires to each component, so you don't need a fuse holder after the distro block. The distro block has that built in.
