Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 11-03-2009, 11:20 AM   #1
Tical84 is an unknown quantity at this point
Basic power related question - Pulse or Constant?
I'm sure the answer is out there but I just can't seem to find it.
I'm looking to purchase an alarm, and I want it to be able to boot my truckputer when I unlock the doors and/or remote start the truck. This is the question I've been asked by the person selling it to me:
"Quick question. How does you truckputer boot up? Does it take a pulse or something or does it require that a constant power source is turned on to boot the computer when you hit the unlock or when you remote started the vehicle?"
I've read people doing this but I can't seem to find that thread anywhere. Can anyone answer this question for me?
Tical84 is offline   Reply With Quote
Old 11-03-2009, 11:41 AM   #2
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
If you are using an intelligent DC-DC power supply like an M2-ATX, that unit requires constant power to be applied to the accessory line to initiate a startup. When it detects a loss of power to the accessory line, it commands a shutdown.
Some units have a boot lockout feature so that once it detects power, it won't check again until some number of seconds later. This is to allow the computer to boot completely before shutting down. It keeps voltage cutouts on the accessory line (like when you turn the key to start the car) from causing a shutdown.
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 11-03-2009, 12:56 PM   #3
Ok thanks. That's what I wanted to know.
How does it work to have the alarm/door unlocker boot the PC since it just sends a pulse does it not? I'm not that familiar with how that part of it works, I'm assuming a relay of some kind would be used but I only vaguely even know what a relay does.
Old 11-03-2009, 01:04 PM   #4
justchat_1 will become famous soon enough
You can use a latching relay to hold power on from a single pulse...or some users with less complex setups will use the pulse to trigger their power button.
openMobile - An open source C# Front End
- Currently Recruiting Developers -
Available for download on sourceforge
justchat_1 is online now   Reply With Quote
Old 11-03-2009, 01:26 PM   #5
Ah, because when you push the button on the front of a PC it's really just sending a pulse to tell the mobo and everything to "turn on" right? Does that mean I actually can just use the pulse from the starter to turn everything on as long as the PSU has constant power?
Old 11-03-2009, 01:27 PM   #6
soundman98's Avatar
soundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the rough
yes, the problem with a constantly on power supply is that it has more potential to drain your battery.
just be careful using the door lock/unlock pulse to start the computer-- on some cars, you need to press the unlock twice--first to unlock the drivers door and twice to open the other doors-- if you hooked this up to the computer, the second pulse would shut the computer off (it would also apply for impatient people like me who press the button more than once ).
soundman98 is offline   Reply With Quote
Old 11-03-2009, 01:32 PM   #7
Right.
I've seen some people rig up the tailgate unlocker on my gen F-150 and they did it so first push unlocks driver, second unlocks the rest, and third unlocks the tailgate. I'm sure if that's doable I could program it so it only turns on after pushing it twice (no need to make it three for me)
Old 11-03-2009, 04:22 PM   #8
Bugbyte's Avatar
If it is a laptop, you can do this without the relay. The pulse will turn it on.
If it is a desktop, doing this will require your power supply to always be 'on'. That drains your battery even when your desktop is asleep. Some of the power supplies will respond to a pulse on (I think the Carnetix ones will).
Want to:
-Where is the iBug?
Old 11-03-2009, 06:10 PM   #9
What can I say? I like serial.
Curiosity's Avatar
Curiosity will become famous soon enough
Most of the PSUs have a pretty long debounce. Maybe 1-2 seconds because the key goes from off to acc, then acc+ign, crank (acc off), and back on so the pulse may need to be extended. I think what people are doing is using the AUX out as constant and just remembering it's on. The range gets pretty short on superhetrodyne receivers when the PC is on so you might have to go out and manually turn it off. Try to find the manuals online. Mine has 4 AUX outs and some are programable as constant or momentary, and the momentary is as long as you hold the button so it can be decoded as tap, double-tap, long press and such with a PIC. Anyway, as far as I know a long enough pulse should start it up and then shut it back down again a couple minutes later.
XPort 1.41 -GPS port splitter, logger, and USB device resume fix
GPS DirectShow Filter / XOBD / MiniCam
Curiosity is offline   Reply With Quote
Old 11-06-2009, 11:47 AM   #10
So is there an alarm with something specific I should be looking for?
Power Button Question for Zotac Users BlueGhost General Hardware Discussion 1 09-09-2009 12:14 PM
Question about monitor and power to it DracoPCGuy Newbie 3 11-01-2008 07:12 PM
Newb question about power from a Molex dsballer2000 Power Supplies 7 06-25-2006 12:32 AM
300 Watt POwer inverter Question XBOX RELATED Porgieanne316 Power Supplies 6 07-21-2005 10:59 AM
Power Supplies Specs Question rushnrockt Power Supplies 4 02-19-2005 02:34 AM
