Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 09-08-2003, 08:13 PM   #1
Post how do u connect lcd screen to computer video card?
i was just wondering how do u connect the video wire from the lcd screen to the computer? Is there some sort of connector that i have to buy? Thanks
lex4style is offline   Reply With Quote
Advertisement Sponsored links
Old 09-08-2003, 08:35 PM   #2
I use an lcd screen with a VGA input. The screen came with the cable to connect to my video card. I bought a 25' extension to run from my trunk to the dash and then some. See the Xenarc, DSCustoms, DigitalWW resellers.
If you're screen only has composite inputs, you'll need a video card with TV out. The text/graphics will not be as crisp and harder to read.
If you can afford it, buy an lcd screen with vga inputs.
tejesh83 is offline   Reply With Quote
Old 09-12-2003, 07:52 PM   #3
You could look online to find a vga to ntsc/pal converter. The ones from AITech are ok. The text isnt that bad either when using one. This will allow you to use your current video card (without tv out) and a LCD that has rca input.
Carputer:
MSI K7T turbo limited ed.
AMD Duron 600
TM - 701 ( Touchscreen and VGA kits will be added later)
ATI Rage Fury
looking at OPUS 150
512 PC100
40Gb HD
SuSE 8.2 Professional
ScYThE is offline   Reply With Quote
Old 09-14-2003, 11:09 PM   #4
SWYZ721's Avatar
Hm I looked at their website and I you need power to actually run that converter? Is that right? How are you powering it? and how do you like the 9000 vid card?
SWYZ721 is offline   Reply With Quote
Old 09-15-2003, 12:49 AM   #5
fluffy2097's Avatar
well. Depending on the LCD you connect it to the video card in any number of ways. Mind telling us what kind of screen it is?
A digital mind lost in an analog world.
Learn to ask smart questions!
http://www.catb.org/~esr/faqs/smart-questions.html
My car PC: The Lost Cause!
fluffy2097 is offline   Reply With Quote
Old 09-15-2003, 08:12 AM   #6
Registered User
mp3z24's Avatar
it sounds like you have a bare lcd board, and depending on the type of lcd you have there are basically 2 options.
if you have yourself a VGA lcd. then you are going to be limited to a (usually expensive) VGA controller board for the lcd. this basically takes the vga signal, a 15 pin signal, and converts it to signals that the lcd can understand (usually a 31 pin signal). the controller card will generally work with a large range of screens so long as you get one that will cover the resoution and color depth of the screen you are hooking up to.
if you have a composite screen, think of the yellow RCA connectors on the back of your TV. this type of connection generally requires a more home-made solution. you basically have to only provide a power source (voltage requirements will vary), a ground, and a video signal. these can be cheaply rigged up, but there is a great difference in quality between the VGA and composite screens.
oh, regardless of which kind of screen you have, you will have to backlight the screen... most screens will come with a backlight, and you will have to provide an inverter. some come with the inverter also, while others come with no back light what-so-ever. so, to help you more, please provide a brand and model of the screen you are trying to hook up. mind you, some screens are very common and they are easily hooked up, while others are a bit more difficult to locate information for.
~Mike
Single Member of the "1000 Post and No MP3 Car" Club
PROJECT ON INDEFINATE HOLD... BOUGHT A HOUSE
2000 Cavalier Z24 [###-------] Only 30% Done ... Still
mp3z24 is offline   Reply With Quote
Old 09-16-2003, 01:32 PM   #7
Some of them can be powered using power off of the ps2 or keyboard port. I havent had a chance to play with it yet. (the 9000) I am actually thinking of not using it.
Carputer:
AMD Duron 600
ATI Rage Fury
looking at OPUS 150
512 PC100
40Gb HD
