12-21-2003, 11:58 AM
#1
connections required??
i jus came across this site last night and i thought it was interesting. I've seen my uncle's onboard computer in his X5 5 years ago, and ever since then i've been thinking about doing it to mine. My main question is what connections/wires do I need to make this thing operate? All I know is that the power from the computer goes to an inverter, but after that im clueless as to what kind of wires i need to buy and such. Is there a site to order these special wires? thnx!
12-21-2003, 12:36 PM
#2
Vehicle: 2002 Altima 3.5 SE
Well, the power to a computer can come from an inverter, but there are other options out there. An inverter with an standard PC PSU is only one of them. A DC-DC solution such as the PW-xx units are better IMO, and are available through this site. Read up on the power supplies forum.
2002 Nissan Altima 3.5 5 Speed Bose FM/6CD ED E12A P4 2.26 512 Ram Ti4600 CDRW DVD Lilliput 200mW 802.11b Trackman AutoTap GPS Opus 150 Carnetix 1260
2005 Nissan Titan SE Dell GX-150 P3 1.0 512 Ram 20G GF4 MX4000 USB 2.0 DVD/RW Xenarc GPS Trackman
12-22-2003, 04:07 AM
#3
Vehicle: 1991 Toyota MR2
Let's see, for my computer, the total wiring neccessary was:
Two 25' spools of 10 gauge (red and black) wire for power wiring.
My audio cables, in order from my mother board:
One RCA-> 1/8" Miniplug converter
Two RCA Audio cables
JVC Aux. In converter
My RCA video cable
One custom Molex adapter I made so my screen could be powered from my power supply
One USB extension cable.
An IDE ribbon cable from my HD to my Motherboard
I think that's it...none of that is particularly special though.
12-22-2003, 05:14 AM
#4
Hi, im a 16 years old Swedish boy that speak and write pretty bad english, but now to my problem. If i have ha PIII with a AGP Graphicard and a Harddrive and a DVD player. All that have a 350 W Powersupply, can i have instead of that one this one http://www.mp3car.com/products/pw-70a.html ? That one is just on 100W or is it not? In sweden we have 220V. I think its stupid to transform it from 12V - 220V and then back to 12V. Can you just not take the 12Volts from the car directly in to the computer?
Best regards Niklas Grahn, Sweden
12-22-2003, 08:07 AM
#5
Vehicle: 2003 Mitsubishi Eclipse GT, 5spd
You should be OK with the PW-70a. It supplies 100 watts, which should be enough for a P3 and drives. You're going to be close to the maximum load on it, though.
One problem you might have is that the PW-70a plugs directly into your system's motherboard. There might not be room on your board for it. So you may need an ATX power extension cable.
So far:
M10000 Nehemiah, 1Gb RAM, Opus 90w PS, Buffalo Tech WLI2-USB2-G54, 160 Gb HDD, GlobalSat BU-353 GPS, iGuidance, Zippy EL-610, Panasonic CW8123B Slim Slot CDRW/DVD, 10" Lilliput, Sony XA-300, Sony CDX-MP30 Head, OBD-II
12-22-2003, 08:41 AM
#6
ok, what else could i use for the Power bit? I know i can use an inverter but those are so damn expensive. So what else could i use to power my PC?
12-22-2003, 09:56 AM
#7
Vehicle: 1995 Chevy Monte Carlo Z34
so your telling me you wouldn't pay $30 for a 400watt inverter? i see them everywhere, Target, Walmart, Bestbuy, hell even Sears has a coule cheap models, they've really come down recently, I paid $65 for my 400 watt inverter in may now the same model can be had for $30, shop around my friend!
12-22-2003, 10:13 AM
#8
in sweden i pay $150 for a 600W and around $100 for a 400W. I think i need a 400W cuz my Power Supply in the Computer is on 350 W
12-22-2003, 01:48 PM
#9
oh your in sweden, my bad! i had no idea they were so much over there. i have a 350 Watt ATX PS with a 400watt invertor and it runs great, you'll probably need the same unless your running more devices
12-29-2003, 08:17 AM
#10
Vehicle: 1993 BMW 325is
I have a 300W inverter running a 450w PSU.. Works fine, because my computer is pulling about 40w, prob a bit less. If you could figure out shipping from US->Sweeden, I bet someone (I'd do it..) would buy an inverter and send it to you. Mine was $35 (I think) shipped from eBay.
1993 BMW 325is - 15.2sec
12-29-2003, 09:53 AM
#11
In light of the cost of the power inverter, I would skip the purchase of the PW70a, and buy a power supply from Opus Solutions. They have 90 watt and 150 watt supplies. They are pricey, but worth it if your alternatives are that expensive, as you would not need an inverter. I don't know what taxes you would incurr getting that from the states. I recommend getting the 150 watt supply if you have room for it - it's larger than the 90 watt. My 90 watt supply from then cost about $170 with the extras I wanted and shipping.
See www opussolutions com for more info.
So far:
| Thread Tools |
| Display Modes |
Linear Mode
