Quote: Originally Posted by Mray
I have been doing some looking around the website here to get an idea as to what this is all about. however I have some questions that aren't easily searchable...
1) Why are some many folks using the Amia (?) motherboard? Why not use more of a traditional P4 equipped board (I apologize...I haven't built a 'puter yet)?
I'm using an Epia M1000 because it is small and consumes very little power, and therefore generates very little heat. I would not have room for a conventional P4 motherboard for my install, and I also do not need it. Ask yourself...what, that you would do in the car, do you need multi-gigahertz processor for? A M1000 will handle DVD's, MP3's, DIVX, GPS...what else are you going to run?
Quote:
2) How are all of you (or maybe just some of you) incorporating an existing (nice and decent) sound system into your project?
3) Are most systems doing away with a CD head unit? If not how are you integrating these into the CPU?
I'm using the onboard sound for the moment...I will probably upgrade to an external soundcard eventually, once I have spending money again. I am using a head unit to interface from my computer to my speakers. This will probably switch to an amplifier eventually.
Quote:
4) Besides a video card and audio card what other cools things can be used with an integrated computer in the car? I would imagine this has an impact on which mother board I choose for PCI slots correct?
Most people add GPS and controllers, but, like Pudge said, almost everything you add will be USB so as long as your mboard has at least that, you're set. Only thing I can think of for PCI cards would be a Bluetooth or similar card, which you can probably find USB, or a better sound card.
