Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 01-13-2004, 06:56 PM   #1
XxAndyxX's Avatar
Mounting the LCD inside the dash?
This is what I was thinking of doing... I am going to make a mold into plaster of my existing dash piece (which is only about a 1'x1') and then shaping it into the dimensions on my LCD screen. Then just pouring the fiberglass into the mold and then I have my dash piece. But how do I stick the screen to the dash piece? Do y'all just use glue?
XxAndyxX is offline   Reply With Quote
Old 01-13-2004, 06:59 PM   #2
robiewp's Avatar
whatever floats your boat. I used brackets/pressure fittings
Use the source, Luke.
car computer rev 3: 8" lilliput and usual suspects
robiewp is offline   Reply With Quote
Old 01-14-2004, 12:59 AM   #3
killerfishes's Avatar
im going to bondo-glass the front of the screen into the stock surround. bondo-glass is vary strong and should hold it fine.
now working on my Dodge Dak
toshiba portege == done
audigy2 NX == done
7" flush mount == 0%
pimp rating == 48%
killerfishes is offline   Reply With Quote
Old 01-14-2004, 05:14 PM   #4
XxAndyxX's Avatar
So you're going to place the screen in the middle of the current dash piece and then just pour bondo-glass to fill on the gaps between the screen and the dash piece?
Old 01-15-2004, 03:05 AM   #5
you can not "pour" bondo-glass but yes. the stock radio opening is just a hire to small for the 7" screen case, i will open it up but leave some overlap and use the bondo glass to fill inthe crack sand it down and paint it black.
this is a good how to on the incorperation of stuff.
http://www.efini.net/dash01.htm
it still would not hurt to epoxy any place you can first as it will hold stronger than the bondo-glass
audigy2 NX == done
pimp rating == 48%
Old 01-15-2004, 08:46 AM   #6
XxAndyxX's Avatar
Do Xenarc and Lilliput screens come with a case like ::THIS::? This is really important to mounting it into my dash.
Old 01-15-2004, 09:23 AM   #7
The Lilliputs do not as far as I am concerned I have never seen them come w/ them nor have I seen them advertised. However I can't speak for Xenarc, my assumption though is no!!
New CarPC on the way again I think. I miss my old one!!!
R3l0ad is offline   Reply With Quote
Old 01-15-2004, 10:27 AM   #8
cotwild's Avatar
hey.. where did you get this picture?
are there any cases for the lilliput screen?
STATUS: planing / building
Car: 85' Audi Urquattro
System: VIA EPIA M10000?, GPS, WLAN, DLink Radio
Display: 7" Lilliput Touchscreen
Power: 300W DC/AC Inverter, OPUS?
Sound: 7.1 Dolby Digital with Audigy2 NX
cotwild is offline   Reply With Quote
Old 01-15-2004, 11:11 AM   #9
XxAndyxX's Avatar
I got the picture off www.digitalww.com it comes with one of his 7" LCD's but it isn't touchscreen. And I don't know if there is any cases for the lilliput that's what I was trying to find out.
Old 01-16-2004, 03:51 PM   #10
The name of the images is a headrest shroud. So you might look for empty shrouds.
Here's some without prices: http://www.millertech.com/headrest-lcds.htm
I'm a newbie - so not sure if these would work. http://www.carmobilevideo.com/category/1.lcdmonitors/
Here are more monitors - but not shroud only: http://www.qualitymobilevideo.com/6-8headrests.html
Hope this helped.
Tom
vwtom is offline   Reply With Quote
cover over lcd mount in dash? Mp3 V General Hardware Discussion 2 05-07-2002 06:32 PM
in dash 6.4" LCD $350!!! moahdib LCD/Display 2 12-14-2001 01:00 PM
Suggested LCD to fit in the dash of a 98 civic? zovirl LCD/Display 4 08-13-2001 10:18 PM
Anyone want a Clarion 5.6" In Dash LCD? gguy LCD/Display 2 05-30-2001 10:29 PM
Mounting LCD to Dash - Won't Stick! DaBretty General Hardware Discussion 3 07-02-2000 12:55 AM
