Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 02-13-2004, 06:14 PM   #16
jol
jol's Avatar
There is a pcb that connects to a laptop hdd and outputs the mp3 file, along with a alpha-numeric display as a addon... But what was the page and the thread....
My cars
jol is offline   Reply With Quote
Old 02-13-2004, 06:55 PM   #17
Raw Wave
Tidder's Avatar
MPXplay, Good dos software. That's what I started out with was MPXplay with the MPXF frontend. I used a 4x20 character LCD and an IRman remote controller. It worked perfect for the time being. I used an old 60mhz processor 12mb ram and a 2 gig hdd. Had it mounted under my front seat. It's good if your looking for inexpensive. I even had a TSR that would show the Long file names: "The Used - Buried Myself Alive.mp3" instead of "theuse~1.mp3" Worked great for me. Boot time was about 4 seconds. MPXplay will also save where you left off, so when you boot back up, it will start in the same place, just like a car cd player. It was good. I have lots of experience with it so if you need help or something, let me know. email removed
Tidder is offline   Reply With Quote
Old 02-13-2004, 07:07 PM   #18
none's Avatar
Yeah, this thread. Look at what I posted higher up, I hadn't seen it here before - but now that I search I do see it. :P
none is offline   Reply With Quote
Old 02-13-2004, 07:13 PM   #19
Raw Wave
Tidder's Avatar
I think this is the device your thinking of
http://www.pjrc.com/tech/mp3/
Old 02-13-2004, 07:17 PM   #20
none's Avatar
The Kitstream is ALOT cheaper and smaller. I'm not saying better, so no flames.
Old 02-13-2004, 08:18 PM   #21
saito's Avatar
Neo Car Jukebox Player
I had one of these in my car for 2 1/2 years before it bit the dust. Good player. Can be purchased sans hdd - add your own. Mine worked through an FM modulator. The random algorithm did suck, a bit, but otherwise solid.
Replaced with a mini-itx carputer.
Aku, Soku, Zan.
Epia M10000 Nehemiah
Lilliput
ITPS Power Sequencer
saito is offline   Reply With Quote
Old 02-14-2004, 09:45 AM   #22
Raw Wave
Tidder's Avatar
I had two of those. Pretty awesome idea. Though I did flash the neo once, and it never worked again. If you do go with the Neo, see if they will flash it with the newest stuff, so you don't have to. Sucks when it doesn't work right.
Old 02-15-2004, 03:15 PM   #23
It`s based on a Micropic processor and the firmware is similar to prjc player.
apos69 is offline   Reply With Quote
Old 02-15-2004, 03:26 PM   #24
Old 02-15-2004, 03:32 PM   #25
More photos.
Old 02-24-2004, 09:41 AM   #26
MPXplay, Good dos software. That's what I started out with was MPXplay with the MPXF frontend. I used a 4x20 character LCD and an IRman remote controller. It worked perfect for the time being. I used an old 60mhz processor 12mb ram and a 2 gig hdd. Had it mounted under my front seat. It's good if your looking for inexpensive. I even had a TSR that would show the Long file names: "The Used - Buried Myself Alive.mp3" instead of "theuse~1.mp3" Worked great for me. Boot time was about 4 seconds. MPXplay will also save where you left off, so when you boot back up, it will start in the same place, just like a car cd player. It was good. I have lots of experience with it so if you need help or something, let me know. Purple_Tidder@yahoo.com
When I used to run a carputer, MPXPLAY was the best simple program I had used. I never got to the remote phase, but was using a keypad. Boots fast, easy to use, and had good sound quality. Even had CROSSFADING. If you only want mp3 and wav files, this is a great way to go.
All this talk is making me want to go back to running a carputer. I knew I came back here for a reason.
prerunnerv6 is offline   Reply With Quote
Old 02-24-2004, 11:11 AM   #27
Here is another MP3 player like the IPOD but a little less expensive and holds 20GB's. Gateway JukeBox
New CarPC on the way again I think. I miss my old one!!!
R3l0ad is offline   Reply With Quote
Old 02-24-2004, 01:08 PM   #28
Quote: Originally Posted by none
http://www.kitstream.com/ If I had found this earlier, I might not have a computer in my car today - this thing seems to do all I need.
is there anyone else on the forum here that has one of these kits in there car? i found this site a while back and tried to contact them, but i never heard from them. they recently updated their site so i'm going to try to contact them again.
Cedrik is offline   Reply With Quote
Commerical MP3 Hardware MooN General Hardware Discussion 15 09-26-2005 04:22 AM
Media Engine - VBcoded vehicle mp3 interface + source CarComp ME Archive 162 11-18-2002 12:15 AM
MP3 costs mp3designer General Hardware Discussion 24 01-29-2001 12:18 PM
Car MP3 Costs mp3designer General MP3Car Discussion 31 01-25-2001 06:19 AM
Do you guyz know this cool machine? Ginger General Hardware Discussion 3 04-19-2000 11:38 AM
