If the car is fairly new you don't have to worry about any fading. You could get that professionally installed. Just check with your local car audio shops. Or if you want I can do it for you.
Blocking the vents would be the best looking way to go. And the air will get rerouted to the other vents making them stronger.
Rich
Quote: Originally Posted by porthos
I don't understand, cut up the new one or the old?!? The car is pretty new so probably isn't very faded. If I cut up either then when I put the stock part back in it will be out of sync but I'll cross that bridge when I come to it.
Ok I have no experience in doing this sort of thing. Basically that head unit you see there is in tatters (I raged at it and left it in a state). I'm at a crossroads, I don't want to purchase a new head unit because it will end my dream of a carputer. I don't know if I can do it properly though, with no experience is it likely that I could get that screen installed professionally? btw I don't care about blocking the vents as long as it doesn't do damage, I read on another thread it just pushes the air out the others harder which is fine. Cheers for your help!
