Just got back from my trip to Home-dept .. The copper Wire idea will not work , from playing around with a few different things it would have a horrible bounce to it as Cherub211 said. I found a few options such as flex brass tubing(for water) that would work , but it would look pretty horrible when all was said in done. but all in all it was a good tri[ as I came up with a few ideas to use for other projects
Quote: Originally Posted by reldridg3
Here is one other thought. I was looking through the McMaster car catalog for work and came across these flexible arms with a locking cam that locks the arm into a given position. goto
www.mcastercar.com and enter in part number 23165a76. This is just a replacement arm cost is a little steep at 35.63 but the replace arm looks like it can just be screwed onto a threaded end and the other end is a female threded end.
This might be something to look at.
I appreciate you looking that up for me .. That does look like it will work with some adjustment. I will do some further research on this part.
Quote: Originally Posted by CoCa
This was taken form the altimas.net forum:
Its called a gooseneck mount I just ordered one for $35.00
Part# PLGN24
From
www.TEPTRONICS.com
Good lord I think that is just what I have been looking for and will fit the bill 100% perfectly .. wooohooo .. thank you for suggesting this
Thanks everyone for all the help they have given me in this thread, it is really appreciated.
Scorpnstail
