Quote: Originally Posted by sohaibma
now please anyone tell me how can i make my car pc shock resistant
Basic common sense. The only component that is really sensitive is the hard drive. Don't use suspension systems that allow oscillation, you need damping. Many people use no suspension at all. I prefer stiff rubber grommits on the hard drive mounting. Don't use anything that would inhibit the drive cooling (eg, foam wrapped around the drive).
I've run the same hard drive for over four years on the rubber grommit suspension with no problems whatsoever.
6yr old first install died 20/8/2005 as result of bad bios flash.
New system : 6x5x2" contains 1GHz C3 PCM9373, ISR based PSU, 8Gb flash DOM, 98Lite, DirectShow based frontend.
GPS : Rikaline 6010.
Display : LTM08C351 + LVDS receiver.
