hi cant get LCD to display anything, it is 40 x 2 HD44780 ive wired it accordin to the following (to parallel port)
printer port LCD
D0 (2) D0 (7)
D1 (3) D1 (8)
D2 (4) D2 (9)
D3 (5) D3 (10)
D4 (6) D4 (11)
D5 (7) D5 (12)
D6 (8) D6 (13)
D7 (9) D7 (14)
nSTRB (1) EN (6)
nLF (14) nRW (5)
INIT (16) RS (4)
+10k pot between +5 and Gnd with wiper to pin3 of lcd.
The pinout (shown above from various websites) matched up with the datasheet so it really seems pretty standard. ive double checked my wiring all seems fine!, the 5v supply is taken from the comp molex connector in the comp (checked 5v). im sure its all grounded right as i can read the voltages on my meter fine and ive checked it all for continuity.
the software im running is:
http://www.markuszehnder.ch/projects...ugin/index.php
and ive played with:
http://backupteam.gamepoint.net/smartie/
but cant get anything to display!!
after searching i found out about lcdprint.exe but that doesnt display either!
my port bias settings are set to EPP+ECP
one assumption i did make when wireing is the numbering of the pins on the lcd as only pins 1 and 14 are numbered. so i assumed they are as follows:
1 3 5 7 9 11 13
2 4 6 8 10 12 14
as i presume its designed to plug into a header! which would be wired in this way and not like the other possible solution!
1 2 3 4 5 6 7
8 9 10 11 12 13 14
is that how they (generally) are wired?
anything else i may of overlooked?
(p.s. it hasnt got hot or smoked yet)
(i went by the number marked on my p.port connector itsself (R.S.) so im pretty sure there right and its not a case of reading it the wrong way round!)
