The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Newbie
Thread Tools Display Modes
Old 04-13-2004, 02:53 PM   #1
My Photos: (0)
will a crank break my harddrive? +HD power question
hi, the question is:
the details are, my system will be laptop powered so cranking not a problem! -but i will have an external harddrive for the MP3's that will require a seperate power supply (12V & 5V) im planning on using a low dropout reg for the 12V and a 7805 for the 5V (i know the nicer way would be to boost the 5V back up to 12V but i cant be bothered (but i might!)), if its running when i crank what will happen to th Hard drive will it just stutter or crash or die?
p.s. how much current does a harddrive (desktop) need, on both the 5V line and the 12V line?
how low can the voltage go on the 12V line before it complains?
i might build a tank circuit -small lead acid batteries are on sale at maplin at the mo! depends on your answears i guess!
sm1thson is offline   Reply With Quote
Sponsored Links
Old 04-13-2004, 03:38 PM   #2
My Photos: (0)
this is not exactly what you are talking about... but i just got my replacement hardrive from WD after my usb external drive died... here what happened...
i was transfering files to it for the first time(brand new) and the power cable to it accidently got disconnected. When i plugged it back in and windows detected it, it told me to format the drive. So i started the format, and that failed and i got data errors from the drive after that.
so i suggest you be really careful with your drive
david_594 is offline   Reply With Quote
Old 04-13-2004, 05:22 PM   #3
Raw Wave
TruckinMP3's CarPC Specs
TruckinMP3's Avatar
Vehicle: '02 suburban with quad captain seating
My Photos: (0)
Hitting a harddrive with the crankshaft is not recommended
Power issues are the worst to diagnose or fix.... Read up and pick your power solution. Better to spend more money on the PS than to have even one problem.
TruckinMP3
D201GLY2, DC-DC power, 14in LCD ;) 3.5 inch SATA
Self Proclaimed Spoon feeder!
Read the FAQ!
TruckinMP3 is offline   Reply With Quote
Old 04-15-2004, 08:02 AM   #4
My Photos: (0)
decided its not worth the risk, -tank circuit it is! just picked got a 12V 1.3AH lead acid sealed bat, for £5 its better safe than sorry.
Old 05-21-2004, 07:06 PM   #5
Vehicle: 1991 Honda CRX
My Photos: (0)
Most drives have this printed on the label somewhere. It's different for different drives.
At work I've had experience working on computers using weak 120VAC (40-60 watt) power supplies. They tend to overheat blow a cap and the output goes out of spec. I've seen drives spin down when the voltage is below 11v, and above ~13.5v too. I think it varies a lot from one drive to another. But I definately have seen poor power kill drives permanently. All this is relating to defective power supplies providing a constant out of spec output, so it may not be relative to a momentary voltage dip from a crank.
mhorton is offline   Reply With Quote
Old 05-26-2004, 12:55 AM   #6
My Photos: (1)
what exactly is a tank circuit? I'm planning on putting in a firewire drive so this might be usefull information...
crashwg is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Power and heat question MpInfiniti General Hardware Discussion 7 08-13-2001 10:36 AM
Removable HD question dudah85 General Hardware Discussion 2 04-17-2001 05:58 PM
power supply question perlmax90 General Hardware Discussion 0 12-07-2000 11:16 PM
Power Supply & TFT LCD question VegaBOND General Hardware Discussion 0 03-23-2000 06:07 PM
Quick Power question BigStud3131 General Hardware Discussion 4 03-16-2000 07:57 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
