Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 04-26-2004, 03:22 AM   #1
slimcubby is on a distinguished road
Need help with info for install of carputer using a laptop...
I am new to this forum I have been trying to find out help with installing a carputer and LCD in dash touch screen. For starters my laptop is a HP compaq nx9010 2.4GHz mobile intel P4 40gig HD 192mb RAM Windows XP Pro and I would prefer using this rather than buidling a carputer from scratch. Will this be possible? How can I make the laptop boot up when the ignition is turned on and shutdown when the ignition is turned off. Please help me here is a link of a similar car to mine but with everything installed and working :-( and with the stock stereo in the glove box. This guy has his computer in his trunk. I would like to have mine under the passenger seat so I can have easy access to the DVD drive. etc. Please help me out with information and help.
Here is the link of my laptop specs
slimcubby is offline   Reply With Quote
Old 04-26-2004, 04:19 AM   #2
skippuff54 is on a distinguished road
man, you gotta search
try looking for
opus for power
lilliput and xenarc for LCD
audi because that's the type of car you drive
any combination of laptop, compaq, intel, and p4 because that's what you want to use
try searching in the forums that pertain to your question. for instance, if you have a power supplies question, search in the "power supplies" forum. or if you have a general hardware question, try the "general hardware discussion." this theme follows throughout the boards.
notice that there is no "walkthru" section.
good luck in your research.
skippuff54 is offline   Reply With Quote
Old 04-26-2004, 07:29 AM   #3
FreeDrive Creator
CdRsKuLL's Avatar
CdRsKuLL will become famous soon enough
that laptop is a bit OTT to be honest. I'm using a laptop, but it stays in the car all the time, I bought it just for the job second hand. The HP laptop you have would be a major waste to just have it stuck in the car all the time. Saying that.. I can remove my laptop easy as all the cables are connected to a docking station. If you were after removing the laptop when not in use then a docking station is a must. I was lucky in the fact that the dell docking station I got had a power button, thus was modded and it now turns itself on when power if given, and its set to turn off after 10 mins of running on batterys. This saved me having to open the laptop and take wires off the power switch. As for mounting it under your seat to access the dvd, yep I agree but that model is usb 2.0 so theres nothing stopping you mounting it in the boot and adding a usb2.0 dvd drive up front. Theres so many ways you can tackle it.. thats what makes these forums so enjoyable to read.. its nice just seeing what people get up to.. theres no right or wrong way to do things really. Its what ever suits your needs
CdRsKuLL is offline   Reply With Quote
What is better for a carputer, a Laptop or Miini-itx pc? abmw Newbie 12 04-15-2004 03:31 AM
Newbie asks ? Laptop based carputer vs desktop pc based carputer SAScooby General Hardware Discussion 2 03-01-2004 02:59 PM
laptop carputer - noobie needs help :) bigdongers Newbie 7 11-22-2003 09:19 PM
Using laptop in carputer? Henry Winx General Hardware Discussion 8 07-22-2003 07:34 PM
Any info on this laptop dvd drive tapper1999 General Hardware Discussion 3 01-15-2002 04:54 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
