Ok here is what I'm planning to try to build. I have never tried putting together a carputer of any kind so any feedback would be great.
My plan is to just have a harness to put the laptop in on the passenger side foot well. The 7" Lilliput touch screen would be mounted and would connect to the laptop's VGA connector. Everything else inside the center console hopefully will reach the laptop through a single USB cable.
inside the center console I was thinking of mounting a:
A USB Hub, don?t know if I have to power the hub or even how to do it if I would need to. The USB connection for the touch screen would be plugged into the hub as well.
USB gps receiver (I read a post that said it would still work through the plastic)
USB SoundBlaster, this has the RCA output to connect to the head unit.
Connections for the OBDII
Some sort of power for the lap top.
All these would be plugged into the USB hub and only 1 USB cable would be going out to the laptop so it would be easy to take in and out.
Optional things:
Firewire or USB DVD ROM. If there is room I would like to put in one so I won't have to access the laptop's DVD-ROM. I guess I would need a power supply to power the drive.
Any ideas how to power the laptop without an external cord plugging into the cigarette lighter (I was hoping to have most of the cords come out of the same hole)?
Is there any way to put the laptop into hibernation or turn it off when you shut off the ignition?
Is this even feasible? Has anyone else successfully done this? Please advise. Thanks!
