Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 05-01-2004, 10:50 PM   #1
Motherboard Vibrating, will it be damaged??
Hey guys,
Done alot of reading and I dont like bothering you guys with questions unless I cant find the answer from searching. I know people have concerns with harddrives and vibrations, but I want to know about the actual motherboard?? I have two 10" subwoofers behind the seats of my truck and built a open section in the middles of the subs for the HD, Motherboard and power supply. After securing it all to rubber mountings, the motherboard CPU, fan, and most connectors vibrate. I know something l9ike this would affect a HD, but what about damage to a Motherboard?? Thanks Fern
syclone477 is offline   Reply With Quote
Old 05-01-2004, 11:28 PM   #2
since everything on a mobo is solid-state, i think you'll be fine, with one exception: the heatsink/fan. I'd be concerned with it possibly shaking loose depending on its own size/weight. If its nice and light, you'll probably be fine, but if its not, then you might want to figure out a way of better securing it. I think it be better if the board layed flat, so it could bear the weight of the HSF straight on, instead of it hanging, but that might still not be enough. another thing to think about is the magnents in the subs. 10 inch subs have got some hefty magnents and they might **** off the motherboard. But that is just a thought as I don't really know what i am talking about. hope i helped,
ray
raypsaliga is offline   Reply With Quote
OPUS PROBLEMS: Please post here if your Opus may have damaged your motherboard. guitar333 Power Supplies 109 05-31-2004 09:07 PM
FS: Casetronics C134 and EPIA M9000 Motherboard jusatry Classified Archive 13 05-17-2004 04:38 PM
WT: Celeron Setup for Slot A motherboard EBoundEE Classified Archive 2 04-28-2004 03:06 PM
Wi-Fi Ehternet PCI Card - Is my motherboard PCI Local BUS 2.1 Compliant? smoldyr General Hardware Discussion 1 11-14-2002 07:56 PM
getting an odd motherboard to power on karmann Power Supplies 13 11-28-2001 05:27 PM
