Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 05-04-2004, 03:03 AM   #1
scw5179d is on a distinguished road
Cool OPUS 90W , I can not shut down my car-pc
I got BIOS instruction for EPIA M-series but I got EPIA. It is different, slightly. I tried my best but the computer reboot after 2 seconds of shut down. No reply from Kris.
Anyone using EPIA 8000 motherboard with OPUS power supply?
It does proper shut down but it reboot again. I pull the fuse out to stop the computer because it will shut down (every 20 mins) and reboot 2 seconds after every shut down.
My BIOS setup problem ???
Ign ACC connection problem??? (I have connected to the cig lighter.)
Please help. Everything else works great, it wount shut dowm completely.
scw5179d is offline   Reply With Quote
Advertisement Sponsored links
Old 05-04-2004, 04:07 AM   #2
Odie
can't run the opus from cig lighter only. You need a constant +12v (like from your battery) as well.
Odie is offline   Reply With Quote
Old 05-04-2004, 04:14 AM   #3
Raw Wave
Confused's Avatar
Confused is on a distinguished road
Make sure "Restart on AC Power Loss" (or equivelently worded) is set to No.
You will also need it hooked up directly to the battery, and the IGN wire needs to be hooked up to your ignition.
Garry
Co-Developer of A.I.M.E.E
www.aimee.cc
Confused is offline   Reply With Quote
Old 05-05-2004, 01:41 AM   #4
nada
I hook up the
red wire to battary with 15a fuse in between
Black to ground
Blue to the cig lighter (put a switch in betweeen)
It would not shut down. Let me go check the BIOS again.
Old 05-05-2004, 03:37 AM   #5
nada
BIOS checked, auto restart --disable
Old 05-05-2004, 05:25 AM   #6
nada
no, still rebooting
Car 5.1 Dsp Options Vs Pc 5.1 Dsp port20 Car Audio 13 05-29-2006 03:10 AM
Couple of questions about OPUS 90W Bxscig Power Supplies 0 04-13-2004 11:27 AM
Opus 90w Power Action EBoundEE Power Supplies 12 03-10-2004 10:11 PM
will pcchips 748 mobo work as a car pc? hud General Hardware Discussion 2 03-10-2004 09:55 PM
About power Supply to PC in car Sk8te General Hardware Discussion 2 11-11-2000 11:39 AM
