Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 05-28-2004, 07:42 PM   #1
Snootch's Avatar
Snootch is on a distinguished road
What is the optimum amount of memory?
What is the optimum amount of memory using a M-10000 and winXP? When I searched, the only thing I could find was that 512MB would take longer to write to the HD during the beginning of hibernation than a 256MB stick would. BUT I know XP is a memory hog, as I'm using 1GB of PC3200DDR in my desktop. Since i'm limited to only one stick of memory, should I purchase one stick of Corsair 256MB, or a stick of Corsair 512MB?
Oh, P.S.: I plan on using the carputer for mostly MP3's, then video, then GPS in that order.
Snootch is offline   Reply With Quote
Old 05-28-2004, 09:57 PM   #2
henkbliek's Avatar
henkbliek
Windows XP just needs around 128 for itself, to any additional depends op the applications you are going to use. For most situations 256 will be more than enough.
I am going to use 256MB for a WinXP system with Destinator2 and my own media player based on DirectX/Directshow and that will be enough, even with swap disabled...
white bream
working on a trilogy: CARGO - UNIGO - MERGO
CARGO = the Car Computer
Intel Celeron M, [P]SDC, uBlox GPS, GPRS, WLAN, Silabs FM, RDS, TMC,
Dual-audio, Onecable TFT, Microsize: 45 x 108 x 168mm (1.8 x 4.3 x 6.6")
henkbliek is offline   Reply With Quote
Old 05-28-2004, 10:21 PM   #3
Raw Wave
god_of_cpu's Avatar
god_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond repute
Go on a machine with windows XP and run all the apps your going to run in your car at any one time, do a ctrl+alt+del, select the task manager then go to the performance tab check out how much physical memory you have availble. subtract that from your total memory to get how much is optimal. You might want to turn off the swap file before you do this to get a more accurate count. My optimum amount is no less then 384 MB.
StreetDeck.com Developer (I am Chuck)
Get StreetDeck at http://www.streetdeck.com
The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
god_of_cpu is offline   Reply With Quote
Old 05-28-2004, 10:26 PM   #4
samc's Avatar
samc
512 megs.. I don't know if thats too much, or too little or even if my windows xp even uses that much during operation. I just picked 512 and was done with it
Mine needs to be updated.
samc is offline   Reply With Quote
Old 05-29-2004, 02:38 AM   #5
noodles's Avatar
noodles is on a distinguished road
256mb sounds good. Sometimes it takes longer to boot if you have more memory.
noodles is offline   Reply With Quote
Old 05-29-2004, 02:34 PM   #6
Walleye is on a distinguished road
dont know... i had 256 and it took slightly longer to boot into XP. like 38-40 seconds. when i went to 512, it went down to 33 seconds. when i went to 512 DDR, it went down to 30 seconds flat.
This is on a 1.8 ghz Duron, and a mobo that supports both SD and DDR ram.
Walleye is offline   Reply With Quote
Old 05-29-2004, 03:21 PM   #7
Snootch's Avatar
Okay, but what about for carputer use, where you want the boot-up and hibernate times to be as fast as possible using XP. Would using good-quality RAM in a 256 stick (e.g. Corsair, Mushkin, Geil, etc.) Give the best results over using say 512 or 256 of generic PC2100 DDR on this board?
WORKLOG
Asus P5N73-AN Mobo/Celeron E1400 2Ghz Dual Core CPU/2Gb GEIL PC3200/120GB HDD/DSATX PS/8" Phylon TS
Webpage
Old 05-29-2004, 03:22 PM   #8
this is my carputer i was talking about. i still havent gotten around to optimizing the boot. that's simply a fresh XP install.
Old 05-29-2004, 04:15 PM   #9
Hcomplyr's Avatar
Hcomplyr is on a distinguished road
I have had just as much luck with generic ram as i have with name brand chips. I've run 128 in windows XP fairly well it could even play some games smoothy, going to 256 made a huge difference in the multimedia dept, so i would think 256 is the minimum if your running DVDs and DIVX in XP
Hcomplyr is offline   Reply With Quote
Old 05-30-2004, 02:32 AM   #10
Snootch's Avatar
I found this PC3200 memory for the same price as generic memory... Would this be a good choice?
http://www.newegg.com/app/ViewProduc...145-025&depa=1
WORKLOG
Webpage
Old 05-30-2004, 01:51 PM   #11
Hcomplyr's Avatar
Look around some more I got 512 of 266Mhz DDR ram for $60 a couple months ago
Ultra Low Profile Memory "wheres it at" tyronepatterson General Hardware Discussion 1 08-28-2004 09:26 AM
Power Seat Memory llmask General MP3Car Discussion 1 03-22-2004 12:14 AM
Via Epia 800 Memory issues... gospeed.racer General Hardware Discussion 1 02-27-2004 02:51 PM
Help with Real DOS, memory managers, and sound card drivers bombboyer Software & Software Development 7 04-11-2003 07:10 PM
Epia m9000 Frying memory? Spongebob General Hardware Discussion 25 03-03-2003 08:22 PM
