The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Newbie
Thread Tools Search this Thread Display Modes
Old 05-31-2004, 11:01 PM   #1
Registered User
My Photos: (0)
5v power to USB SB Audigy 2 NX
Hi,
Hope someone here can help out. I just got a SB Audigy 2 NX External USB and need help getting power to it. Can I simply hook up the 5v and GRD from one of the molex connectors off an OPUS 90w PS and splice into the barrel connector that's supplied? Will this work? Any other suggestions?
Anyone know the size/type of barrel plug that is supplied? I may just want to get another one so that I can keep the current plug the way it is.
Thanks for your help!
Shayne
shillier is offline   Reply With Quote
Sponsored Links
Old 05-31-2004, 11:03 PM   #2
elmo_eats_rust's Avatar
Vehicle: 2004/Saturn/Ion
My Photos: (0)
That's what I did, works fine.
elmo_eats_rust is offline   Reply With Quote
Old 05-31-2004, 11:13 PM   #3
Raw Wave
rando's CarPC Specs
rando's Avatar
Vehicle: 2004 Toyota 4Runner
My Photos: (0)
Yep, works for me.
2004 4runner
rando is offline   Reply With Quote
Old 06-01-2004, 01:07 PM   #4
d_sellers1's Avatar
Vehicle: 2000 Ford Taurus & 2001 Ford Focus ZX3
My Photos: (0)
Another job for the multimeter, With the power cable plugged in figure out which is positive and which is negative. You can then either cut the wire or go to RadioShack and get one (Adapt-a-Plug). Take the cable with you. It's a lot easier to figure out what you need when you have it right there in front of you. It's what I used to make a long cable for my radar detector that goes into the headliners, down the A-pillar, and under the dash. Anyway, using the continuity tester on the mulitmeter just hook up your connector to the molex plug. Think the red one is 5V and black (obviously) will be your ground. Double check the voltage to be sure in case I'm wrong. (1 out of 2 chance.)
d_sellers1 is offline   Reply With Quote
Old 06-01-2004, 01:22 PM   #5
Raw Wave
rando's CarPC Specs
rando's Avatar
My Photos: (0)
I just opened up the Audigy and soldered on a standard PC molex connector.
2004 4runner
Old 06-01-2004, 03:05 PM   #6
Snootch's Avatar
Vehicle: 2000 Pontiac Trans Am
My Photos: (0)
What is the sound quality difference between the built-in AC97 audio and the Audigy? Audible? Better?
WORKLOG
VIA SN18000/1Gb GEIL PC3200/100Gb 2.5"HD/8" Phylon TS/BU-353 GPS/Powermate/M2-ATX PS
Webpage
Snootch is offline   Reply With Quote
Old 06-01-2004, 03:42 PM   #7
My Photos: (0)
The Audigy 2NX is much better... and I ran my power from the 150W Opus 5V rail as well, never had a problem!
Litespeed is offline   Reply With Quote
Old 06-01-2004, 10:00 PM   #8
Registered User
My Photos: (0)
Which wire is positive, which is ground?
forgot to ask... which wire is positive, which is ground? the adapter and barrel plug that came with the audigy has a black solid and black/white wire...
Thanks again!
Old 04-27-2005, 10:06 PM   #9
-zip-'s CarPC Specs
-zip-'s Avatar
Vehicle: 2000 Protege
My Photos: (1)
Thanks again!
I am wondering the same thing..
At a GUESS I would say the black/white (dashes) would be the positive wire.... yes?
Carputer
Installed Since April 2, 2005
Intel D201GLY|Fusion Brain|Audigy2 NX||ODBPros ODBII|Engenius362ext |Motorized lilli|GPS Rikaline 6010|Opus 150|Powermate|Ergonomic Touchpad|
Sound Stage
Eclipse CD8455|MTX TA3404+421D|Infinity Comps|ID 12" Sub
-zip- is offline   Reply With Quote
Old 05-03-2005, 09:12 PM   #10
-zip-'s CarPC Specs
-zip-'s Avatar
My Photos: (1)
ran a multi meter.. it is the dashed line works fine
Carputer
Sound Stage
Sponsored Links
Old 05-03-2005, 10:16 PM   #11
maxxell's CarPC Specs
Vehicle: '05 Subaru WRX STi
My Photos: (0)
This sounds amazingly like what I had to do to run a molex to the +5v in for my USB hub. I didn't know which wire was +-, so I opened up the part that came with the hub that plugged into the wall (that I had just thrown away). On the board in there it was labeled.
Sounds like you can do something similar to find which to run.
A car without turbo is a car with perpetual lag.
My Ride
My New Page
maxxell is offline   Reply With Quote
Old 05-04-2005, 05:25 PM   #12
d_sellers1's Avatar
My Photos: (0)
When in doubt, use a multimeter. They are invaluable (espically since it prevents burning up your electronics or yourself).
Derek
Progress [||-------]
View my Worklog to see some of my progress.
Downgraded Progress - Starting with another car... 09/13/06
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
-5V power supply gizmomkr General Hardware Discussion 7 05-30-2007 02:00 PM
Audigy NX remote nick9871 General Hardware Discussion 15 11-14-2004 06:19 PM
USB SB Live! Drivers Pudge General MP3Car Discussion 9 05-23-2004 04:02 PM
5v power? daver LCD/Display 6 10-26-2001 06:27 AM
need help on -5v power noproblem General Hardware Discussion 6 07-10-2000 11:37 PM
Sponsored Links
Ad Management by RedTyger
