Quote: Originally Posted by 702civic
I plan on putting the computer under the front passanger seat. With easy access to the dvd-rom and usb ports if needed. Now for the questions
1. How much heat is a problem while the computer is not in use? I live in Las Vegas so it can get upwards of 150 degrees in my car.
2. How much do I need to know about electrical engineering to put all this together? I know how to put the computer together, but what do i have to actually do in car?
3. What do you recommend for putting your LCD in dash? Can I get this done at a stereo shop?
4. What are the chances I can seriously mess up my car? This is my one big worry. If I put a grand into the computer and fry it, well worse things can happen. But if i destroy the electrical system in my car ill be in deep do-do. haha
1) I don't hink heat would have a huge impact while off. I'd insure a good cooling setup so that it won't get too hot when it's on.
2) You need a phD!
Seriously... The connections are pretty simple. You're connecting power leads from the battery to the P/S with a fuse somewhere in the middle.
3) It's fabrication work. I'd check around for a local shop that does fab work (some shops will farm it out because they don't want to do it themselves) and ask to see their work. The other option is to get an in-dash LCD. There are in-dash VGA units that are unorderable presently. I'm waiting for one of those for a good clean look in my install.
4) Unless you b0rk the wiring or attempt to hook into any of the car's electronics, you should be OK. As far as the connections to the car, it's little different than an advanced stereo setup.
