Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 06-13-2004, 06:23 AM   #1
d_sellers1's Avatar
d_sellers1 is on a distinguished road
Using the OPUS to shutdown other stuff
Is it possible to use the OPUS to shutdown/turn on other electronics such as an AC-DC invertor? My thought is this:
The wires going to the motherboard power switch is, in essence, an ON-OFF switch. Can I tap those two wires and wire it in to an inverter (replacing its power switch)?
Would the shutdown delay work for this kinda of setup? What I mean by this is if the power supply is set to have the computer hibernate after 20 minutes, will this "switch" be turned off? This way the equipment will still be on when the car gets turned off and will be turned off after the 20 minute day?
Would a relay be needed? If so, what exactly do I need? I know absolutely nothing about relays. I've got RadioShack nearby and that's about it...
Possible uses for this application:
- Turning ON/OFF AC-DC power inverters
- Turning ON/OFF a secondary DC-DC power supply if the OPUS is overloaded (this one can run the power to hubs and such)
- Turning ON/OFF amplifiers
- Turning ON/OFF fans, lights, and neons.
Any other suggestions or ideas?
Derek
Progress [||-------]
View my Worklog to see some of my progress.
Downgraded Progress - Starting with another car... 09/13/06
d_sellers1 is offline   Reply With Quote
Old 06-13-2004, 06:51 AM   #2
Raw Wave
Laidback's Avatar
Laidback is on a distinguished road
The Opus is for ATX style boards, on these the motherboard power switch isn't an on-off switch. It just needs the two connectors shorting together for a second to turn the computer on, short them together again and the computer shuts down.
You could take 12v from a drive connector and use that to control a relay/relays.
What are you going to use an inverter for?
Laidback
Laidback Carputer
Laidback is offline   Reply With Quote
Old 06-13-2004, 09:03 AM   #3
d_sellers1's Avatar
Okay. Makes sense about using the 12v drive connector. That'll serve my purpose too.
The inverter will be for anything I need that requires AC power (that I can't make run off direct DC current) and also give me AC power in my car. That'll be great for power tools!
Derek
Old 06-13-2004, 09:20 PM   #4
Raw Wave
rando's Avatar
rando is on a distinguished road
OK, but why would you want your power tools to be triggered from your Opus? It seems like it would be simpler to trigger your inverter from ACC rather than the Opus.
2004 4runner
rando is offline   Reply With Quote
Old 06-14-2004, 03:10 AM   #5
d_sellers1's Avatar
Okay. Think I lost some people here. First, the inverter is just to allow me to have 110VAC in the car. This was I can run either 12VDC or 110VAC stuff.
This setup would simply allow me to go to having everything on when I turn on the car. Wiring the DC-AC invertor to the ACC or ignition will accomplish the same effect that is just another set of wires to hide. Since there will be wires coming from the computer, all the wires can be make to look neat in one easy step.
Derek
Old 06-14-2004, 04:07 AM   #6
Raw Wave
Laidback's Avatar
Derek
Having the Opus switching the inverter on/off is one thing.....and powering the inverter from the Opus is another. Don't forget you only have a limited supply of power on the Opus 12v rail, minus whatever the computer is already using. I doubt whether you could power it from the Opus so you'd still have to run wires....
Laidback
Laidback Carputer
Old 06-14-2004, 04:29 AM   #7
Man
Man's Avatar
Man is on a distinguished road
Derek
Just use your cars wiring harness, there is a wire that will be ~+12v when the key is in the on position and 0v when the car is no in the on position. You can then use this to turn your relays on/off, its a lot simplier method han having them on only when your computer is on, you still have to wire this wire to your opus to turn on when the cars on, so why not your other devices?
Man is offline   Reply With Quote
Old 06-14-2004, 05:38 AM   #8
no1knows's Avatar
no1knows is on a distinguished road
u need to take +12v and GND from the opus supply which is yellow and black from any HD/floppy connector. connect this to a 12V relay coil.This can switch the + side of the inverter line. Wouldnt sugges tpowering high power tools off this, but thatll do the job up to 30A or higher if u get a chunkier relay. 30 x 12 = 360W total power, maybe 300W taking inefficiencies into account.
HTH
Mods: 18" Boss rims,Twin custom stainless exhaust,cold air induction.
Sound: Pioneer 7400 HU & 6x9's,12" Vibe Sub,600W Kenwood amp.
CarPC: MicroATX, Inverter, WinTV, Lilliput 7", USB GPS
http://www.no1knows.com/galleries/
no1knows is offline   Reply With Quote
Old 06-14-2004, 01:16 PM   #9
d_sellers1's Avatar
The intent is not to have wires going from every which direction. It makes it harder to troubleshoot problems. I will already have a USB and video cables running form the computer in the trunk up to the front seat. Two small wires run in this bundle can easily be made to look neat with some split loom. +12VDC will have a drop located near the center console that I will connect rocker switches to turn on/off. This is also where the inverter will get its power. The computer will receive power from a battery in the trunk running through an isolator. I just don't want to have to turn the inverter on and off all the time. I may have something running in the car that needs AC power.
I highly doubt the Opus will power the inverter. I may turn it on but I have a feeling that it will easily overpower the Opus real quick.
Derek
Old 06-14-2004, 11:54 PM   #10
Raw Wave
rando's Avatar
Right, i understood you the first time. You want to use the Opus to trigger not power your inverter. To do so, you'd use the opus to trigger a relay and the relay would switch a +12v battery connection going into the inverter. Thus the inverter would come on whenever the computer was on.
I'm not clear on the specifics of your particular setup, but it is hard to imagine that doing it this way will truly make your wiring look any cleaner. There are usually switched accessory and/or ignition signals all over a car. ANY of those could be used to trigger your relay rather than the Opus output. Moreover, at least one of these switched signals is already an INPUT to your Opus. Instead of taking the Opus +12v output, why not just tap the ACC input from the Opus. I mean the two wires are in the EXACT same location. What am I missing here?
Regardless, as far as functionality goes, the two solutions are nearly the same. With the Opus doing the triggering, your inverter will have a slight delay before it turns on / goes off. With the ACC direct triggering, the inverter will be on/off with your key (a bit more traditional). Either way, you won't need to use the power switch on the inverter. You can just leave it switched on.
Good luck.
2004 4runner
Old 06-15-2004, 07:48 AM   #11
d_sellers1's Avatar
The other biggest thing for running it through the Opus would be to utilize its delayed shutdown features. This way when I fill up for gas or something, everything is still running even though the car has been turned off. Tapping the ACC in any location won't achieve this.
Derek
Old 06-15-2004, 08:05 AM   #12
StationRocket's Avatar
StationRocket is on a distinguished road
there is a good primer on relays here
http://www.the12volt.com/relays/relays.asp
also i just opened the owners manual for the 90W Opus that you can download in the Porducts section of this site and there is a diagram showing you how to do this sort of thing on page 8 in there.
good luck
StationRocket is offline   Reply With Quote
Old 06-15-2004, 09:16 AM   #13
d_sellers1's Avatar
good luck
12Volt.com appears to be a real good site. Got a lot of reading to do...
Thanks for the information from the Opus 90W. That's exactly what I've been looking for. I had downloaded the 150W manual but it doesn't say anything about this capability. Can anyone confirm that the 150W has the Remote/Trigger Switch that the 90W does?
Derek
PS: The 90W manual is 11 pages while the 150W is only 8 pages.....
Derek
Old 06-15-2004, 09:49 AM   #14
Raw Wave
rando's Avatar
OK, this motivation makes sense. Here's how you can do it.
Opus+12V---RelayCoil----GND
BATTERY----RelaySW----Inverter---GND
Make sure you get a 12V relay with a switch rating higher than the maximum draw of your inverter. For instance, a 12V 30A SPST Normally open relay would be sufficient for 360W load (input rating of your inverter, not the output) or approximately 250W inverter depending on the efficiency of your inverter.
You might also want to throw a diode across the relay coil or buy one with a diode built in. This dissipates the current from the collapsing magnetic field in the coil from potentially damaging your Opus or other attached devices.
Opus+12v---<|----GND
2004 4runner
Opus 150w idle shutdown problem? ŠuTcH Power Supplies 2 06-10-2004 04:19 AM
Opus 10 second shutdown delay antimatter Power Supplies 1 06-09-2004 01:31 PM
Opus 90w Shutdown Power off Porblems antimatter Power Supplies 8 04-15-2004 12:24 PM
Can you adjust shutdown voltage on Opus 150w? Visual Echo Power Supplies 4 03-26-2004 09:04 AM
Does your Opus 90 surive crank and perform shutdown? quinxy Power Supplies 13 03-07-2004 12:45 PM
