The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Newbie
Thread Tools Search this Thread Display Modes
Old 10-27-2004, 02:58 PM   #16
My Photos: (0)
acutally, the preamp out from a pc is better than most head units. I replaced my sony headunit and sound quality improved quite a bit. My brother replaced his Alpine head unit, and once again, quality improved quite a bit.
14" LCD, EPIA MII-10000, 256MB, Wireless LAN, GPS, CDRW/DVD, ELM Scan,
200wRMS inverter (for the screen), CarPC Pro v2.4 Power Controller,
2 12" Pioneer Premiers, Sony 6x9s, Sony Xplode Class D mono block, Pheonix Gold A/B amp for highs
ColdPhreze is offline   Reply With Quote
Sponsored Links
Old 10-27-2004, 03:15 PM   #17
ash
ash's Avatar
Vehicle: 82 firebird se / 80 cadillac eldorado
My Photos: (0)
Quote:
How do you do this? Dual monitor setup?
(Corect me if i am wrong) The MII 10000 has onboard vga and composite/S-video out. You can run the Vga to your 7'' and the S-video/composite to a splitter and then to your screens. It's all onboard the motherboard
they made me laugh
"Damn pounds. Euros and USD!" - N09
"don't ruin my dreams! my parents did plenty of that " -Hcomplyr
ash is offline   Reply With Quote
Old 10-28-2004, 12:46 PM   #18
Laptop, Tablets, UMPC Moderator
turbocad6's CarPC Specs
turbocad6's Avatar
Vehicle: 2002 pontiac montana
My Photos: (77)
I have found that most pc soundcards, internal or external usually have an output voltage in the 2v range, whereas a high end head unit will be at least 4v & some are as high as 8v. this makes a real difference when you are running multiple amps. & I don't think pc hardware manufactures ever consider this as a probability, (there's a business oportunity for someone inclined to do that) you can add line drivers to help remedy this, I have done one with an external usb soudblaster extigy & it worked well., the side benifit of a setup like this is that that particular soud card will also funtion stand alone, without the pc if necissary, & you could play a different source through it with the pc off & still have volume control through it among other features.
at this point in time I still think that an all out competion system is still better of being based on a hybrid system as oposed to a full pc front end, maybe this is just my opinion, but I have had a lot of experence with both pc car installs & competition in car audio, for whatever that's worth. check out this thread for more input on this:
http://www.mp3car.com/vbulletin/car-audio/35156-can-carputer-replace-high-end-av-dedicated-system.html
MY NEWEST INSTALL:modded infiniti fx with big screen - "If my typing sucks it's probably because I'm driving....................."
turbocad6 is offline   Reply With Quote
Old 10-31-2004, 10:13 AM   #19
DiB
My Photos: (0)
I have a loud system in one of my cars; 152db loud. I would think about using one of those usb flash drives as your system HD. It will be a bit slower then normal but all the vibrations from the bass wont affect it unless you build a custom HD harness to deaden the vibrations on a normal HD. I know this is one reason for me going to a carputer, my cd changer can't run without skipping.
For your connection woes you might need a better EQ, or a line driver, or if you still have a free pci slot there are a nice selections of sound cards that can output to almost any connection type. I run all zapco gear so I just run one of their inline amp cables from the av brain to the amps. With the right sound card and eq/signal processor it's not hard unless you want perfect sound which costs several thousand.
Look at some audiocontrol products if you aren't already familiar with them.
DiB is offline   Reply With Quote
Old 12-04-2004, 05:37 PM   #20
rmjjensen's Avatar
Vehicle: 1992 Subaru SVX
My Photos: (0)
Well, if you have such an extreme setup than don't mess with a sound card honestly. Just get something with a digital output and use a digital signal processor to split the signal the best. Why?
Pros
-You'll have a high preout voltage from the DSP
-You'll get the cleanest possible sound form the computer
-You're completely isolating the grounds from the computer and the audio system
-You won't get noise
-You have control of the volume
-You can plug a LOT of input devices into the DSP
-Signal Processing
-Dolby Digital/DTS Surround sound capabilities
-Built in crossovers/Equalizers in the DSP
Cons
-Expensive - but with all the money invested in the audio system you don't have a choice
I strongly recommend the PXA-H701 from alpine ...probably the best investment I made with my setup.
Good luck with everything. But I have strictly a computer in mine with no issues. Was able to reach 146dB with just the 2 subs I got. Don't worry - the computer hardware will still function, just make sure it's all SCREWED down!!
rmjjensen is offline   Reply With Quote
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
First Car PC Questions - Pretty Long Post Sorry :D [56k death] FiReToY Newbie 9 06-08-2006 05:15 PM
help putting together car audi/control system ikOnone Newbie 9 02-28-2004 09:51 AM
Car with no system..How do I wire the speakers to my MP3 system? fogleroller General Hardware Discussion 10 02-14-2002 02:46 PM
car audio and MP3 cars donalson General MP3Car Discussion 10 11-30-2000 09:04 PM
Is this a good computer for a car mp3 system ? mprover General Hardware Discussion 8 08-10-1999 05:37 PM
Sponsored Links
Ad Management by RedTyger
