Go Back   MP3Car.com > Mp3Car Technical > Newbie
Notices
Old 06-30-2004, 01:03 PM   #1
Ripsurf's Avatar
Need help with installing carputer
HI all... I am completly new to the whole carputer thing just need some advice on wiring the carputer to the car. I have brought 150W opus power supply but im not too sure how to hook it up to the car battery i have also brought this cable set of ebay too http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWN%3AIT&rd=1 as far as i undersand that this cable set will be ok too use?? also just want to make sure that i connect the positive from the car battery to the positive on the opus power supply and the negitvie from the car battery to the negitive on the power supply then just wire the ignition wire to the igniton??? sorry if this sounds really stupid just dont want to blow anything up.. i did try a search to see if i could find a diagrame but i found nothing
Cheers in advance
Ripsurf is offline   Reply With Quote
Old 07-01-2004, 04:00 PM   #2
See me in my wet t-shirt.
stevieg's Avatar
Yep, looks like it should work fine.
Use a multimeter to test all 12V +/- connections before wiring up - but it is quite simple, the red wire goes to the red connection on your battery and then is connected to the Opus red, and so on.
Do you have a copy of the Opus manual - that has instructions on the wiring.
I also tested mine on a 12V dc inside the house first to make sure everything was OK before installing in the car.
The ground (negative) is usally best grounded to a grounding point near where the Opus is - the Chassis should be grounded, once again test your grounding point using a multimeter and check it is low resistance (ensuring it is a good ground)
Ford Focus MP3 : www.stevieg.org/carpc
Car PC Status: COMPLETE
stevieg is offline   Reply With Quote
Old 07-01-2004, 04:14 PM   #3
binary.h4x's Avatar
Nice find on the install kit, it looks like a VERY good deal. Only thing is, you will not be able to run your ground cable back to the battery. So do as stevieg suggested and find a good ground point near the carputer.
binary.h4x is offline   Reply With Quote
(Div)XBox Carputer (warning: many pics) Richie Show off your project 41 09-01-2005 06:24 PM
semi-newb, need help planning for carputer in a Mazda3 Stealth915 Newbie 9 10-23-2004 03:25 AM
unusual question: hook up cd changer to carputer Tufail Newbie 4 02-16-2004 10:08 AM
Thinking of selling my old carputer for an ipod churnopol General Hardware Discussion 2 10-15-2003 11:10 AM
This new motherboard should make installing a carputer MUCH simpler. Szech General Hardware Discussion 8 11-08-2001 01:41 PM
