Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 07-14-2004, 03:22 PM   #1
barometer's Avatar
barometer is on a distinguished road
Wiring question
I bought a Carnetix power supply and the optional wiring kit that came along with it. The wires for example the power wire that is connected to the battery is small I'm guessing 18 guage wire. Shouldn't the power cable that needs to be connected to the battery be around 4-10 guage? I searched but couldn't find a definitive answer on this. If this wiring kit cable is so small how is it to be hooked up to the battery. If anyone can enlighten me it would be greatly appreciated...thanks.
barometer is offline   Reply With Quote
Old 07-14-2004, 03:28 PM   #2
b_nom's Avatar
b_nom is on a distinguished road
It doesn't need to be a big gauge if it will only draw 5amps (60W at 12V), which BTW is what the carnetix PS is rated for
'96 Chevy Cavalier - EPIA M10000, Win2K,MediaCar, Deluo GPS Mouse with Routis, 60GB external HD, 7" widescreen monitor from DigitalWW.
'00 Jeep Wrangler - planning stage
What can BROWN do for you?
b_nom is offline   Reply With Quote
Old 07-14-2004, 06:35 PM   #3
MikeH is on a distinguished road
Barometer,
The +12V and GND wires in both J1 and J2 are actually 16GA. The are fairly short and are meant to be used as a splice point for the longer wires coming from your battery. You should use a larger gauge wire from your battery (10-12GA should be fine) to prevent having too much of a voltage drop during cranking. Since the J1 and J2 wires are short, they will not affect the voltage drop much during cranking.
FYI...during cranking, if your CarPC is drawing 5amps, the battery will actually be supplying almost 10 Amps to the PSU!!
MikeH
MikeH is offline   Reply With Quote
Headless Setup - Quick Amp Wiring Question. crosseye Car Audio 6 07-13-2004 03:18 PM
wiring question? lopan Power Supplies 4 01-07-2004 09:38 PM
Audio Wiring question.... jusatry General Hardware Discussion 16 01-02-2004 03:08 PM
A question (or two) about wiring Thartek Power Supplies 9 08-07-2002 08:34 PM
Silly question about Wiring SuperMatty Power Supplies 8 02-10-2002 02:23 PM
