Quote: Originally Posted by GeddyT
Now my goal is to run the audio from the PC into the auxiliary input behind the head unit so that when the head unit is set to aux, it'll play what's on the PC. And program the IBUS so that when a CD is in the head unit, the steering wheel buttons control the head unit and when aux is selected, the steering wheel buttons control the PC (I know NOTHING about doing this, so I would need some help--that is, if it's even possible...). Also it would be nice for the skin to automagically turn to the nighttime skin when the headlights turn on through IBUS.
I don't mean to discourage you in this regard, but I think you are wanting to do the nearly impossible (very difficult anyway). I don't think it is possible to have the steering wheel controls do BOTH the PC and factory head unit at the same time. One or the other I think...The nightime skin via headlights would be difficult/impossible to figure out too. For the amount of work it would require, I would just be satisfied with interfacing the steering wheel controls with the PC.
Here are the things I'm a little sketchy on (eternal thanks for input):
1.) Has anybody else out there made this work without removing the factory head unit? My main reasons for keeping it are the high quality radio receiver, the ability to easily and quickly throw CDs in, and that it looks good. That and it will allow me to keep the factory amp for now and therefore put off another fat wad of spending.
I know that some peeps have opted to keep the factory head unit. I ditched mine and put the screen in its place. Will you really use the radio and CD player that much if you have all your CDs on your PC anyway? Just a question - maybe it is a better option for you to keep the factory head unit, but I decided it wasn't something I wanted to keep. Especially because I managed to make a custom mount for the screen that makes it look OEM.
2.) Is PC audio --> auxiliary input adapter --> factory radio gonna sound like whales crapping?
If you are a music purist at all, I would guess that you wouldn't be happy with it. At the very least, get a USB external sound card - that will clean up the audio some. More than that, use a good quality line driver (
www.audiocontrol.com - I use the three.1)
4.) Video signal from the trunk all the way to the center console: Long VGA extension the way to go or will that add too much noise and there's a better way that I don't know about?
Xenarc sells an extension for their touchscreen. This is what I have and it works flawlessly. I'm not sure about Lilliput. You definitley have the opportunity to add a lot of noise if you get a poor quality VGA extension and don't run it appropriately by running it next to power lines etc.
Good luck with the project - my advice is just jump in. You will figure out a lot of stuff on your own as you forge ahead but ask questions in this thread thoughout the project. Also, make sure to
a tonne - there is actually lots and lots of E46 info on this board.
