Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 09-28-2004, 05:54 PM   #1
popuptoaster's Avatar
popuptoaster is on a distinguished road
Question Full size PC if space is not a problem?
Right, im new at this and it'll be my first car PC application, although i have built a fair few home PC's in my time.
I run about in a hearse so space isnt really a problem (I have 4 feet of legroom between my front and rear seats, 5 foot of rear "boot" area, lots of headroom, and large boxed in areas all down the side of the car) Its all getting refurbed and rebuilt around the PC/ICE inside.
I have been running fairly hefty ICE for years in my cars so the hearse is getting a pretty showy install, and i want to make the rear seating area, very "limo" like, with a widescreen LCD in the roof behind the front seats, a touch screen LCD in the front, possibly 2 15" LCD screens facing out of the car right at the rear of my tinted side windows so they are invisible from outside untill switched on.
I also want full dolby 5.1 for watching DVD's and the ability to add sat nav, web based traffic and weather updates, WiFi for the service stations and anything else i can think of as i go along, there will also possibly be other aplications, such as computer controlled light shows and other equipment.
My plan is to run my stereo install from a deep cycle battery (or 2!!!) mounted in the rear that has a split charging system and so isnt reliant on my vehicles main battery, because space isnt a problem, Im working on the theory that i may as well build a full size PC in one of the premodded cases and have it mounted into a side panel running from my extra battery via a DC-DC converter.
I should be able to get a much better performance per £ than if i was to build up a mini PC with the added benefits of more room to add cards and extra features, and the ability to use the PC for actuall gaming.
Are there any difficulties i do not see? Is there a way of telling the PC to hibernate when the vehicles ignition is switched all the way off? will an LCD screen function ok if it just gets its 12 volts direct from a battery rather than its transformer?
Any suggestions/comments/insults?
popuptoaster is offline   Reply With Quote
Advertisement Sponsored links
Old 09-28-2004, 06:37 PM   #2
Bobby Digital is on a distinguished road
If you use an Opus DC-DC power supply, it has built in shutdown functions, or you can buy a shutdown controller. Opus might not support a really high power system though, although I hear they're coming out with a 300w model.
The LCD should come with a cigarette lighter adaptor thing for plugging into a car (12V). This will help regulate the power. Just cut off the lighter adaptor and wire the wires to + and -.
Bobby Digital is offline   Reply With Quote
Old 09-28-2004, 06:39 PM   #3
jimmythecow is on a distinguished road
pics please
When in doubt, moo at things.
jimmythecow is offline   Reply With Quote
Old 09-28-2004, 06:51 PM   #4
pip
pip's Avatar
pip is on a distinguished road
If space isn't an issue then using a full sized system will be cheaper and allow more options. Even if the box is full sized there are still power/heat constraints. Even with a full sized case I would recommend:
1) Using a mobile processor.
2) Keeping the heatsink small/light (or mounted to the case somehow) to prevent damage to the mobo.
3) Avoiding the newest power hungry video cards.
Sounds like an interesting project, keep us posted
pip is offline   Reply With Quote
Old 09-28-2004, 07:29 PM   #5
cooky is on a distinguished road
I've got a '79 dodge clubcab. The kind with the side mount, fold down seats that'll break your back if you even think of sitting in one, and virtually no dashboard to speak of, so I've got tons of room to work with as well.
Power will be the biggest problem with your install. Most of the cars at shows that have massive audio systems and multiple screens are just show cars. Some don't even have engines anymore. I'd run the math and make sure you can power your system before you spend that much money.
cooky is offline   Reply With Quote
Old 09-28-2004, 07:48 PM   #6
Super Moderator & Wal-Mart Greeter
Tidder's Avatar
Tidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant future
As far as this goes, I've been running a P4 2.0ghz desktop processor in my dash with no heat issues yet, for about a year now. I'd say stick with intel because of their themal protection. I guess the way it works is as the processor gets hotter, the mobo cuts back the cpu speed until the heat subsides.
Mount your Motherboard horizontally instead of vertical.
Tidder
Try RevFE
The best frontend I've ever used, period.
Best Quote EVER!!
Quote: Originally Posted by bramlet View Post
I try to search but I usually only find posts where people ask questions and darquepervert tells them to search.
Tidder is offline   Reply With Quote
Old 09-29-2004, 04:19 AM   #7
lovely guys, thanks, so looks like its an intell cpu in a desktop style case, shouldnt have to many power problems as i have been running cars with hefty stereos for years, they may not be as massive as the show cars systems, but who wants a car you cant drive???
anyway, pics of the hearse are linked below, you can see the interior is a mess at the moment, but then again, if it was mint i there, id be reluctant to rip it all out!!
http://img.photobucket.com/albums/v1...e/25c115d7.jpg
http://img.photobucket.com/albums/v1...e/5cac0cc7.jpg
http://img.photobucket.com/albums/v1...e/cfe1926d.jpg
http://img.photobucket.com/albums/v1...e/1f010646.jpg
http://img.photobucket.com/albums/v1...e/c73ae599.jpg
http://img.photobucket.com/albums/v1...e/b9675d70.jpg
http://img.photobucket.com/albums/v1...e/e07f5d6b.jpg
http://img.photobucket.com/albums/v1...e/22b2cefe.jpg
http://img.photobucket.com/albums/v1...e/c4f28df8.jpg
http://img.photobucket.com/albums/v1...e/c709b942.jpg
http://img.photobucket.com/albums/v1...e/3c6bbed9.jpg
Old 09-29-2004, 05:48 AM   #8
tsparks is on a distinguished road
LMAO.. excuse the pun but I wouldn't be caught dead in that thing.. a ford hearse? i'd much rather see it as a mobile theater than a hearse.. good luck
tsparks is offline   Reply With Quote
Old 09-29-2004, 10:32 AM   #9
lol @ that. i want one
Old 09-30-2004, 08:49 AM   #10
DriverDan is on a distinguished road
Wow! That thing is huge. The exterior looks nice. Now all you have to do is clean up the interior and you'll have one pimp ride How do you afford gas for that? It must get 10MPG.
I suggest you go with a micro ATX MB. It's smaller than a normal board but still has AGP and PCI expansion slots. That's what I'm putting in my camper.
89 Mustang (Autox, road race, and cruiser)
93 Escort (Daily Driver)
84 Dolphin RV (Soon to be Carputer Heaven)
DriverDan is offline   Reply With Quote
Old 09-30-2004, 09:22 AM   #11
Nic
Nic's Avatar
Nic is on a distinguished road
it needs a mattress and a mirror ball
Signature: [==||========] 20% complete
Nic is offline   Reply With Quote
Old 09-30-2004, 06:14 PM   #12
Self proclaimed spoon feeder
TruckinMP3's Avatar
TruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud of
Tidder,
Are you saying that due to the mass of the heatsink or a different reason?
The smaller or OEM intel heatsinks should not be an issue even the P4 ones. P3 and older boards it would not matter at all.
TruckinMP3
Read the FAQ!
TruckinMP3 is offline   Reply With Quote
Old 09-30-2004, 08:41 PM   #13
ppgt94's Avatar
ppgt94
That thing is slammed!
ppgt94 is offline   Reply With Quote
Old 09-30-2004, 09:07 PM   #14
MySQL Error
jcdillin's Avatar
jcdillin is on a distinguished road
I love that car, that is so cool.
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 09-30-2004, 09:18 PM   #15
Raw Wave
Spaghetti's Avatar
Location: Spagcave, in da UK Today's phrase: J'aime Alizee
Spaghetti has a brilliant futureSpaghetti has a brilliant futureSpaghetti has a brilliant futureSpaghetti has a brilliant futureSpaghetti has a brilliant futureSpaghetti has a brilliant futureSpaghetti has a brilliant futureSpaghetti has a brilliant futureSpaghetti has a brilliant futureSpaghetti has a brilliant futureSpaghetti has a brilliant future
If you're linking externally, you can do it like this:
Spaghetti is offline   Reply With Quote
Any problem mounting an inverter in the PC case? lifeboat General Hardware Discussion 7 01-16-2002 09:54 PM
Million $ Questiosn: HD screw size and wahz a good PC DVD player? Tony S General Hardware Discussion 14 05-05-2001 02:31 PM
Click here to find the best prices on full size LCD's DodgeMp3Enabled General Hardware Discussion 2 09-14-2000 10:52 PM
book pc & mpxplay problem megane Software & Software Development 0 09-14-2000 04:29 PM
Palm Size PC remote?!? lithium_ion General Hardware Discussion 1 10-22-1999 12:23 AM
