Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 11-21-2004, 07:51 PM   #1
ljstevens is on a distinguished road
Mini ITX in car stereo?
I am new to this mini itx thing, however I build computers so know what I am doing in that respect.
I would like to have a pc in the car, primarily for sat nav reasons. I had a thought of whether you could squeeze a mini itx system into a gutted out car radio/stereo using the mini snap in dc converter, a tiny hard disc, and tiny cd-rom? Any thoughts? If you couldn’t squeeze it in do you think you could squeeze in this new nano itx board in the same way when it finally comes out? I already have one of those 7” screens and they are great!
Any feedback would be much appreciated
Regards
Lawrence
ljstevens is offline   Reply With Quote
Old 11-21-2004, 08:04 PM   #2
Raw Wave
RoyN's Avatar
RoyN is on a distinguished road
Maybe you could.... but there are cases that are 1 din, which is basically the size of a car stereo... why not use one of those with a slot-load dvd drive, and then you have it all....
RoyN is offline   Reply With Quote
Old 11-21-2004, 08:24 PM   #3
grepzen's Avatar
grepzen is on a distinguished road
careful though.. none of them are less than 10" deep
few dashes are more than 8 ish
•Micke
grepzen is offline   Reply With Quote
Old 11-22-2004, 05:00 AM   #4
I was staring at my car stereo this morning, and I reckon its big enough. Mine is only the standard single height stereo (is that what 1 din means?)
Also I think I have a bit of extra room behind the stereo if I need to spill out the back.
I am wondering can you get a slot loading slim line laptop style cd or preferably dvd drive?
Also does anyone know of anyone actually trying to do this whole idea? It seems quite logical that instead of cramming a pc in the glovebox or under the car seat, to put it in the stereo space, and use it instead of a car stereo.
Lawrence
Old 11-22-2004, 05:09 AM   #5
SAScooby's Avatar
SAScooby is on a distinguished road
search dude
there are actually a few succesful installs like this
it is the most logical way to do it, but also from a fabrication way one of the most difficult
Cheers
Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
FS = MTSVO motorised in dash screen pm me for details
SAScooby is offline   Reply With Quote
Old 11-22-2004, 05:10 AM   #6
I have just been scouring the net and it seems that panasonic make these slot load drives! Wow I am getting excited, does anyone else think it's a good idea for this pc inside a car stereo case? If you couple it with the 7" touch screen, then you can control the pc via the monitor. If I could squeeze in a usb radio, or even a pci radio, there is nothing that my current car stereo could do that this new car stereo pc could not!
Lawrence
Old 11-22-2004, 06:58 AM   #7
Raw Wave
RoyN's Avatar
Hi Lawrence...
You are on to something: precisely what everyone here is on to!
Seriously though, that is more or less the purpose of all Car PCs here... Basically the PC does all the things your radio can do + more, and it is cooler...
Your going to have to give the whole thing a try though, and be prepared for failure.... get your stereo, rip it apart, then try to build the computer into it... if it works your a happy camper!
You can also try some autosound stores, or other related shops for just a carcas of a car stereo?
Finally, you can get an external USB fm radio... you can also get XM radio from my understadning in an external usb format...
good luck!
Old 11-22-2004, 07:02 AM   #8
LeoTheHamster's Avatar
LeoTheHamster is on a distinguished road
Buy an Audi TT, it'll make fitting everything in so much easier......
But you will look like a hairdresser
Leo
http://www.talkaudio.co.uk
Quote:
A million people can't be wrong, right?
Well... unless they're all from the red states...
LeoTheHamster is offline   Reply With Quote
Old 11-22-2004, 07:10 AM   #9
IonDokk's Avatar
IonDokk is on a distinguished road
You can fit a Nano board into a single din chasis for a radio, although you will not be satisfied with the sound quality of the board therefore you also will need a good sound card so there goes your single din. You can put a pci riser in and put it right over the mother board but by the time you clear your snap on power supply, your hit...
Epia M1000 1.2gig, Toshiba 40gb HD, Itronix 60gb HD, 512ram,PCR, Audigy2zs, 2 Xenarc 7" , FRODOPLAYER Trying RR frontend , 2@1600/w Harrison labs amps & Caps, Focal & MB-Quart midrange, Diamond Audio D6 Subs, Mb Quart Tweets, 2-Audiocontrol three.1 !
IonDokk is offline   Reply With Quote
Old 11-22-2004, 07:22 AM   #10
Ok guys
I think the nano itx board would be the way to go, however have they actually been released yet - are they available to buy, or are they just being demoed at trade fairs?
If not could i squeeze a mini itx in there? i think the width of mini itx - 17cm (i think) is small enough to fit inside the width of the metal shell of the car stereo
Also one of you mentioned some people have already built one of these, and stated I should search this forum - i tried searching for car stereo but nothing came up - anyone have any ideas what to type in to reveal it in this forum so I can have a look at other efforts?
Lawrence
Old 11-26-2004, 09:14 AM   #11
OriginalNick2 is on a distinguished road
Mate i built a fully ITXsystem and its sooooo much easier thanmessing about with PC sized things!!!
But..... Why cram it into your DIN slot?? my computer is much much loads smaller than a box of cereal - im gonna chuck it in the boot and put an in-dash monitor where the stereo used to be.
ITX also draws much less power! check out:
www.itx-warehouse.co.uk
www.mini-itx.com
thats wherei sourced all my parts from.
Good Luck
Nick
OriginalNick2 is offline   Reply With Quote
Old 11-26-2004, 11:56 AM   #12
jbors's Avatar
jbors is on a distinguished road
I think just taking DIN size radio case won't work. The best way is to build your own case or use already prebuilt case.
Car pc integration with ease
Car mediacenter
jbors is offline   Reply With Quote
fs: car, stereo, cpu items kingnasty Classified Archive 1 11-12-2004 06:02 PM
Bargain!! Via Epia Nehemiah 1ghz Mini Itx Mainboard dave0109 Classified Archive 8 05-26-2004 07:40 AM
Mini ITX MB? HELP fondoo General Hardware Discussion 6 05-06-2004 09:46 PM
found a car adapter for mini itx case! e36mp3 General Hardware Discussion 7 08-04-2002 05:06 PM
Dose anyone know where I can buy the Mp3 Neo car stereo? nitris Classified Archive 2 11-01-2000 03:22 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
